Old 03-18-2006, 09:31 PM   #1
xagna
xagna has a little shameless behavior in the past
Does Nismo or Kazama engine mounts lower the engine compared to the stock mount?
If not, is there any engine mount that can put the engine lower into the engine room thus achieving lower center of gravity?
xagna is offline   Reply With Quote
Old 03-18-2006, 09:34 PM   #2
Ritz S14
Ritz S14's Avatar
I don't think lowering the motor would be a good idea. Lower oil pan = more possibilites of damaging it.
Ritz S14 is offline   Reply With Quote
Old 03-18-2006, 09:39 PM   #3
xagna
In that regard, lowering the car itself is not a good idea too. But you have your point. Thanks for your 2 cent.
Old 03-18-2006, 09:55 PM   #4
Ritz S14
Ritz S14's Avatar
Yeah, but lowering just the motor will leave the oil pan more exposed, than if you were just to lower the car itself.
Old 03-18-2006, 10:42 PM   #5
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
I have not compared them, but I read that Cusco ones lower the motor 1in.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 03-18-2006, 10:51 PM   #6
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
stock motor mounts have the engine lower because they are used !!! as the durometer decreases the weight bears down on the mounts and the motor drops lower. This explains why when you install new mounts, the motor sits higher. Simply put, new mounts position the motor where it should be when mounts are new, even with stock mounts.
*light bulb obviously wasn't clicking for you*
only mounts that would be comparable are R32 mounts, heavier motor = higher durometer. Search for some R32 mounts. Done and Done.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 03-18-2006, 11:23 PM   #7
xagna
Thanks for explaining about age affecting the engine mounting height. Now, do you know any engine mount that lowers the engine or keeps the current height?
Old 03-18-2006, 11:29 PM   #8
OptionZero
OptionZero's Avatar
keep current height= keep current mounts
lower engine = custom mounts
if you are at the point where you actually care about center of gravity AND can measure it AND are driving hard enough to notice the difference regularly
THEN you should have access/money/interest to having the fab shop do the work for you, it's just some metal work and shit at that point
OTHERWISE, stop reading, pick up your keys, and drive. Seems like a little knowledge here went a long way...in the wrong direction
Old 03-19-2006, 10:38 AM   #9
xagna
"if you are at the point where you actually care about center of gravity AND can measure it AND are driving hard enough to notice the difference regularly."
I noticed a difference in cornering right away after installing a strut bar in the front. I noticed a difference in rolling after I lowered my car down by an inch so I had to raise it back to bring the roll center back to original location. So yes, I do care.
Now I just found out that Nismo mount for CA does lower KA because CAs sit low. Where can I get this CA engine mount?
Old 03-19-2006, 12:05 PM   #10
Jason@performance
Jason@performance is making a name for him/her selfJason@performance is making a name for him/her self
Send a message via AIM to Jason@performance
The NISMO Mounts are made to factory spec except with the higher durometer rubber...
If you were to hold them next to eachother you wouldnt see much difference until you push down on it.
The CA mounts look very similar to the SR / KA mounts but the little stubs sticking from the top of the mounts are in different locations... The R&L mounts on the CA look to be a little shorter then the SR/KA mounts...
(We just got more CA NISMO mounts instock... PM me for forum price)
Jason@performance is offline   Reply With Quote
Old 03-19-2006, 01:32 PM   #11
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
FYI, I believe the USDM driver side CA engine mount is the thin one, not both. Use 2 of those in your KA/SR and it will sit lower...but those are the mounts (LH) that are usually out of stock with places that carry them (possibly not the case with the poster above?)
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 03-19-2006, 11:29 PM   #12
Jason@performance
I have them..
Ill take side by side pictures tomorrow of CA / SR mounts next to eachother...
Old 03-19-2006, 11:58 PM   #13
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
Originally Posted by BigVinnie
CA's do not sit low. Oil pan location is still set in the same place as if it were a KA or even an SR. What makes a CA look as if it sit's low is it's block deck heigth which would appear to make the engine look as if it was sitting lower than an SR or KA. Which KA has the tallest deck heigth of all 3 of those engines. (aren't nismo s13 mounts all the same?)
You have no idea what you are talking about...
Nismo SR/KA mount on the left, CA mount on the right-
Again, SR/KA on left, CA on right-
The CA mounts are DEFINITELY smaller than the KA/SR mounts. Driver side is almost 1/2" shorter and pass side is about 1/4 to 1/3" shorter.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 03-20-2006, 12:06 AM   #14
S14DB
AFC #1
S14DB's Avatar
I have seen vendors advertisers selling this point also. I have them on the shelf and don't know how they support this claim.
Old 03-20-2006, 12:09 AM   #15
boosteds13
boosteds13's Avatar
Go compare them to your stock mounts and see if there is any noticeable difference. Even if your stock mounts are worn out, they wouldn't sag as much as the height difference they advertise.
Old 03-20-2006, 12:10 AM   #16
Jason@performance
beat me to it!
Im just not sure the motor would even seat properly on the CA mounts.. If you look at them from the top you see what I am talking about... ?
Old 03-20-2006, 12:25 AM   #17
boosteds13
boosteds13's Avatar
Originally Posted by Jason@performance
beat me to it!
Yeah... I know the CA sits a much more radical angle than the other motors which could possibly cause an oil starvation issue.
Old 03-20-2006, 06:24 AM   #18
curbhuggerrps13
curbhuggerrps13's Avatar
curbhuggerrps13 is an unknown quantity at this point
Send a message via AIM to curbhuggerrps13
wow this thread was very helpful..all those who contributed gets a +1
curbhuggerrps13 is offline   Reply With Quote
Old 03-20-2006, 12:26 PM   #19
Jason@performance
Right Mounts:
SR on the Left
CA on the Right
Left Side Mounts
SR on the Left
CA on the Right
The most noticeable differences...
On the Right mounts... The CA rubber going to the bottom part pictured is not as wide as on the SR/KA mount.
On both mounts, the SR/KA metal is thicker then the CA ones...
On both mounts the SR/KA mounting studs are longer with more threads then the CA ones...
On both mounts the SR/KA mounting dowel pins on the frame are longer then the CA ones...
On the top of the SR/KA mounts the dowel on the motor side is further from the stud then on the CA ones...
hope this helps?
