F/S: 91-Rare 180sx HARDTOP/SR/AC/5 LUG...
Hey guys, welp- as much as it sucks ass to do this, I need money bad right now. Please note that I built this car because I love the 240/180 as a car, not because it's "cool". This car has been built by the professionals at IC AUTOWORKS. Nothing on this car has been half-assed! However, I am in a tight jam so, I'm selling my 180sx. Here are the specs:
1991 Nissan 240sx Hatchback 191K on chassis 63K on motor, 13K on motor since installed ***THIS SR20 HAS COLD AIR CONDITIONING****************** Gunmetal ext-Black/suede int RARE HARDTOP w/ POWER EVERYTHING EVERYTHING WORKS! STRAIGHT FRAME, CLEAN TITLE NEVER RACED ON ANY TRACK!!!!!!!!!!!!! NEVER DRIFTED AT ANY DRIFT DAY!!!!!! ULTIMATE SLEEPER ****ALL WORK PERFORMED BY IC-AUTOWORKS. ask Jspec.com or phase2motortrend, both had their cars worked on by IC-AUTOWORKS*** I have a set of Tanabe sway bars, F & R- brand new, not installed. they were supposed to replace the whitelines.Whiteline anti-sway bars BNF20Z 27mm *Adjustable * Front Bar Whiteline anti-sway bars BNR20X 20-22mm *Adjustable * Rear Bar Rear Upper Control Arm Bushings (SPF1638K) Rear Lower Control Arm Bushings (SPF1639K) Rear Camber Correction Bushings (KCA347) Rear Nissan Subframe Bushings (KCA349) Front Lower Control Arm with SPF1009K Bushing pressed in. SPF1202K TC Rod Bushings Cusco Front Camber Plates KYB AGX Shocks with Eibach Pro Kits Springs Nismo Mechanical 2 way LSD kit SUB-FRAME BUSHING SET #16 & #17 (55400-RS590--) Cusco Strut Tower Bar Front Oval Shaft Cusco Strut Tower Bar for Rear Aluminum Shaft Cusco Front adjustable pillow mounts Tomei 1.2mm Metal Head Gasket ACT Street Clutch Walbro Fuel Pump Blitz 3" Stainless Downpipe HKS Turbo Extension 180SX Cluster (7500RPM Redline/9000rpm tach) Equal Length Manifold Upgrade to R134 System Custom AC Line Toda Flywheel Computer Upgrade Nissan Gasket Set Tomei Rocker Arm Stopper HKS Blow Off Valve w/Recirculation Blitz Down Pipe S14 O2 Sensor Steel Braded Oil Return Steel Braded Slave Line 300ZX Slave Clutch 300ZX BRAKE UPGRADE S14 5 LUG UPGRADE - FRONT AND REAR ** E BRAKE WORKS PERFECTLY!** 5zigen FN01R-C 17x8 all around 225/40/17 Michelin Pilot Sports all around- 60% tread left Steel Braded Fuel Lines with Red covers sr20det water pump Chrome Nut Caps Blow Off Valve weld Installed 3 Accessory Belts Input Heater Hose Output Heater Hose NGK Iridium Plugs Nismo Thermostat Blitz Front Mount Intercooler Optima Red Top Battery *BATTERY RELOCATED TO REAR* Greddy Oil Catch Tank Clifford Alarm Sony CD/MP3 headunit Alpine V12 amp Infiniti kappa speakers (4) 300ZX Clutch Master Blitz 3" Exhaust HKS 42mm Oil Pressure Gauge Crank Angle Sensor HKS Boost Gauge 52mm HKS Holder S14 cloth seats installed! S14 seatbelts installed! JDM 180sx tail lights installed ***the trunk key has been re-keyed to be used by the original key*** PICTURES ARE AVAILABLE @ http://ziff.net/~danny/240sx asking only $11K OBO! please feel free to contact me anytime-626-831-2181. [email protected] I am located in the so. cal area. |
