www.turbo-kits.com T3/T04e Turbo Kit?
I am looking at buying a turbo kit for my S13 SR20DET and was wondering if anyone knew anything about turbo-kits.com? They seem to have a prety nice kit for the price but I was wondering if anyone has installed this kit and had any fitment issues or problems? You can view the kit at:
http://www.turbo-kits.com/240SX_turbo_kits.html I am looking to make around 350-400 wheel horsepower. I plan on installing a metal headgasket and such but do no plan on building my motor. I emailed them about trims and they replied with, "T3/T04e 46, 50, or 60, stage 2, 3, or 5 (depending on the trim) with .48 or .63 a/r...". The FMIC dimensions for the cor are: (3.5 x 6.52 x 24). What do you guys suggest? Thanks |
Alright guys, I talked to a specialist about the kit, and what else I might need. Here is the list:
Ceramic Ball-Bearing T3/T04e Turbo (Stage III Wheel, 60 Trim, .63 A/R) Thermocoated Cast Steel Manifold Thermocoated Mandrel-Bent Downpipe Turbonetics Evolution 35mm Wastegate 3” 16 Gauge Mandrel Bent Intake Pipe Spearco W.A.V.E Front-Mount-Intercooler (Core: 3.5 x 6.52 x 24)Space Available: (27”L X 8”H X 3”D) or (27”L X 10”H X 2.25”D) Silver Metallic Intercooler Piping (Cold Pipe for Greddy Manifold) Turbonetics Raptor Blow Off Valve (BOV) K&N Air Filter Install Instructions and Wiring Diagrams All Necessary Hardware and Fittings $2,975 for everything above 850cc Sard Injectors $400 Apexi Power FC $920 SPEC Stage 4 Clutch Kit $370 Fidanza Lightweight Flywheel $330 ER Custom 1.1mm Metal head Gasket $140 ER Stainless Rocker Arm Stoppers $70 Peak Performance Pro Transmission Bushing $50 NISMO Motor Mounts $100 Z32 MAF $150 Around $5,500 plus the tuning What you guys think about this setup? He said I should be making anywhere from 350 to 400 wheels hp safely. Hope it all goes to plan... Any comments would be appreciated. Thanks |
#3 | |
![]() Join Date: Dec 2005
-The Flywheel, its good but not essential, -the injectors, for 400 hp: 720cc are perfect, even 550cc are ok, -the Apexi PFC is awesome, but you can also get your stock one re-tuned by a couple companies for half the price of the PFC...(I got mine done at JWT (500$)and I have the Z32 and 855cc injectors also,,, (burns fuel like a MF**)... -the spec clutch (stage 4 ) is good for like 800HP ..you dont need that! the stage 3 is fine and is cheaper, its also good for 650 HP..I have It... its great for drifting... Also keep in mid you will have to spend money to have the items installed, and the PFC will have to be tuned, Unless you can do the work yourself. and since you will be doing Head Gasket, you should go ahead and do internals all at once..it'll save you the headache later... The setup is good for 400 HP for sure. Hope I was usefull....just trying to save you some $$$$$ |
