Old 04-11-2006, 11:03 AM   #1
mmtmatrix
mmtmatrix is an unknown quantity at this point
Battery Relocation Question
Hello everyone, sorry for the battery questions but searched and couldn't quite find what I was looking for.
Anyway, am in the process of doing a battery relocation on my S13 hatch. Went to get a battery distribution block from an audio electronics store where a friend works and ended up buying a monster kit because he was able to give me a discount.
My questions are; This kit comes with 22 feet of 4 gage wire (for wiring an amp), I was planning on using this for my power cable, some people say 4 gage is fine, others say that it will be too small? Thoughts?
For those running batteries in their trunks, where/how did you route the power cable? I am leery about going under the car due to damage from road conditions, but also am unsure about through car due to heat and EM damage (possible to ecu?). What have others done?
Also, it came with a fuse, should I use this?
Thanks for all the help,
mmtmatrix
mmtmatrix is offline   Reply With Quote
Old 04-11-2006, 11:38 AM   #2
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
i ran zero guage just cause i had it i also have two fuses on mine one in the trunk and the other under the hood also went under the car believe me its not that common especially if you ask someone who has done lots of stereos
bigOdom1 is offline   Reply With Quote
Old 04-11-2006, 02:39 PM   #3
Mr. Badlose
Mr. Badlose is an unknown quantity at this point
Send a message via AIM to Mr. Badlose
Hmmm, I think most relocation kits use 2 gauge (like my Summit one), but you'll have to try it and see. I honestly don't think it'll cause any problems. I routed my cable under the rear seat, pulled up the carpet on the passenger side, routed the cable under some metal structure close to the center console., and then drilled a hole and poked it through the firewall. I did this when I was at an automotive school and I asked a couple instructor's about possible EMI...and they said it would be alright.
Mr. Badlose is offline   Reply With Quote
Old 04-11-2006, 03:10 PM   #4
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
I used 4 gauge. It sucks.
Battery never gets a really good charge because of voltage drop across the length. Just run 2 4 gauge wires and you'll be ok.
Maeda is offline   Reply With Quote
Old 04-13-2006, 04:01 PM   #5
mmtmatrix
Yeh i think that alot of kits out there use 2, what do you guys think about 4? Any more opinions?
Also, where should I route the cable?
Thanks,
mmtmatrix
Old 04-13-2006, 04:16 PM   #6
ThatGuy
Admin Asshole
ThatGuy's Avatar
2 gauge or larger. Route it wherever you have room. Easiest is under the car. Tuck it up tight and you shouldn't have any worries. If you don't want to run it outside, pull up the carpet along the bo sides of the car and figure out where the most room is.
Old 04-13-2006, 04:16 PM   #7
Phlip
Yes, I look like that
Phlip's Avatar
Summit sells 2 gauge in the kit that they sell:
http://store.summitracing.com/partde...5&autoview=sku
Weirdo
And I write too!
Old 04-13-2006, 05:09 PM   #8
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
hmm... i was wondering if any of you guys drilled down the box or something to secure it? im scared ima drill to deep and kill my gas tank
IAM_SO_sLOw is offline   Reply With Quote
Old 04-13-2006, 05:24 PM   #9
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
Drill carefully, plenty of room. Just start w/ a smaller bit. Drill a little, then check under the car (easier to see if u jack up the car). I used some m8 or m10 bolts to hold down the tray.
brokeAs240sx is offline   Reply With Quote
Old 04-13-2006, 05:25 PM   #10
Phlip
Phlip's Avatar
I am going to put mine on the driver's side of my trunk, no worries there
Weirdo
And I write too!
Old 04-13-2006, 06:11 PM   #11
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
I used 2 gauge with mine and a fuse block for my accessories. I used 2 battery tie down bolts( the ones with a threaded end and a hook on the other side) measured and drilled 2 holes and put the hooks in the holes.
spdfreek0o is offline   Reply With Quote
Old 04-13-2006, 06:33 PM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
Really? I'm using 4 guage without any problem.
Guess I'll look into upgrading it.
Old 04-13-2006, 07:19 PM   #13
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
smaller wire has more resistance. My teacher said 0 gauge is common but if summit sells 2 gauge kits then I guess that's ok. I probably wouldn't go w/ 4 gauge though.
shayrgob240 is offline   Reply With Quote
Old 04-13-2006, 07:35 PM   #14
NemeGuero
No more nissan.
NemeGuero's Avatar
Yah, I know that it has more resistance. It was a pre-existing wire that I had run for my amplifier.. I was just too lazy and too cheap to buy a new one and run it, instead of just using what was already there..
I have yet to have a problem with it.
