Old 04-14-2006, 12:45 PM   #1
evil_tt
evil_tt's Avatar
evil_tt is on the path to ruinevil_tt is on the path to ruin
What parts needed with Megan susp. Can I clear tires?!
I am getting Megan Coilovers in a week and I am not to sure if I am going to clear my tires. I have DT-05r's 16 x 7.5/ 16 x 8.5. Would I need spacers? If so, would I need longer hub threads? Thanks guys.
evil_tt is offline   Reply With Quote
Old 04-14-2006, 12:56 PM   #2
slider2828
slider2828's Avatar
I have 17x8 +35 FN's all around I needed at least a 10mm spacer in front and I could clear the rears without a spacer probably. So probably to be on the safe side pending on your offset of the front, I would maybe do a 10mm in the front, and maybe a 10mm in the rear.... It should work. I used kics spacers, no hub bolts needed cause they just bolt on, but you need to shave the existing hub bolts so they don't hit your rims....
Old 04-14-2006, 02:24 PM   #3
evil_tt
evil_tt's Avatar
Cool thanks, my offsets are +22 in front and +37 in back
Old 04-14-2006, 02:29 PM   #4
slider2828
slider2828's Avatar
So probably 10mm in the front or even 5mm might clear cause +35 - 15= 10 offset, but I think +15 will work for you, so you can probably get 10mm spacers in the front 10mm in the rear.... look up kics spacers
Old 04-14-2006, 03:10 PM   #5
Irukandji
There's a thread on wheel fitment.. maybe you should search.
16x7.5 +22 will be fine for front
16.8.5 +37 will be fine for the rear too.
You don't need any spacers. The most you'll need is a 3mm spacer for the front, but I doubt it.
You can use your factory wheel studs, but dont go bigger than a 6mm spacer without using a bolton spacer.
Old 04-14-2006, 03:14 PM   #6
evil_tt
evil_tt's Avatar
Im looking at getting them right now, there is some different mesurments there is 10mm/12x1.5mm & 10mm/12x1.25mm, what are the different measurements?
Old 04-14-2006, 03:20 PM   #7
evil_tt
evil_tt's Avatar
Thanks you for the info
Old 04-14-2006, 03:22 PM   #8
Irukandji
Don't get the expensive bolt on spacers.. you don't need em.
Just go to Autozone and get the metal spacers you throw in between your wheels and rotors.
Old 04-14-2006, 03:52 PM   #9
evil_tt
evil_tt's Avatar
/\ Im going to do that tonight, Thanks!
Old 04-14-2006, 03:52 PM   #10
evil_tt
evil_tt's Avatar
i think they sell the 5mm spacers last time i was there
Old 04-14-2006, 03:57 PM   #11
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
Hey man, as far as I know, those wheels will clear coilovers. At least that's what I was told when I bought them from Touge Factory a year or so ago.
S13 Charlie is offline   Reply With Quote
Old 04-14-2006, 04:15 PM   #12
evil_tt
evil_tt's Avatar
haha, dude, I bought these rims from you, hows the 13?
