Old 05-08-2006, 07:16 PM   #31
cc4usmc
cc4usmc's Avatar
what about 1jz? is that still not legal? i have seen the other threads but i cant find the one that talked about California regs on swaps. i swore i saved it as a favorite bud i dunno what happend to it.
cc4usmc is offline   Reply With Quote
Old 05-08-2006, 08:29 PM   #32
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
^ I'm no expert but the 1jz you hear about being swapped into 240s are the jdm ones not the ones we got here hence they won't be smog legal. Forget the details. I'm sure Aaron can chime in.
Old 05-08-2006, 10:31 PM   #33
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Heres my 2 cents and why.
If you are going KA-t build it right. Using cheap and affordable Altima/Xterra/frontier KA pistons drops the compression to 9.2:1, and these ringlands are thicker than the 240sx piston ring lands. This means higher boosting and more power, without the worry of frying rings.
You also live in cali, KA's are abundant at wrecking yards with parts (ecu's, heads, etc) gallore.
After market support is becoming better for the KA.
Hell obviously you were SR, now maybe it's time to get some low end torque youve never felt before. Torque band on the KA is much smoother and linear, thatsa great thing since you just have to shift a tad earlier than the SR.
Might as well let the V8 guy's feel your 2.4litre turbo charged WRATH....
Just my 2 cents....
BigVinnie is offline   Reply With Quote
Old 05-08-2006, 10:36 PM   #34
cc4usmc
cc4usmc's Avatar
i would never put in cheap parts. if i want ka-t it would be rebuilt using rebuild kit ams240 offers, but it would be the complete one here
http://www.amsperformance.com/store/...roducts_id=303
i just found a s14 ka-t for sale in my area and i want it. no i have to see if i can get enough for my car since he doesn't want to trade...
Old 05-09-2006, 01:13 AM   #35
Id-
Id-'s Avatar
Id- is an unknown quantity at this point
Originally Posted by tre
both will be pains int he ass, dont do it. get a ticket mailed to that adress. You not mail it in in 15 days. Get pulled over and hauled off to jail? I wouldnt want to.
LS-1 Will throw off the weight distribution HORRIBLY in the car.
BUT it is up to you.
Yeah it will throw it off HORRIBLY on the car. It weighs less than the KA and has the same length and sits lower in the engine bay. Man thats horrible.
Research your facts before you make uninformed comments.
95 Lexus SC300 5-speed
-DD pimp car
92 Nissan 240sx base coupe
-clean KA24DE swapped in
-GTIR T28
-Big FMIC
-565cc STi Injectors w/ Z32 MAF
-J30 VLSD w/ subframe spacers
-RPS Max clutch
-3" turboback
-PLMS Daughterboard on modded ECU
Id- is offline   Reply With Quote
Old 05-09-2006, 01:15 AM   #36
Id-
Id-'s Avatar
There are several 1jz swaps here in the states. Garageworks iirc has done one. Pretty slick. Cheaper, stronger, more plentiful and more powerful in stock form than the RB25. Also has a higher power potential. Its a 2jz with a shorter stroke (same rods, same pistons, different crank, block deck height is just shorter)
-DD pimp car
-GTIR T28
-Big FMIC
-RPS Max clutch
-3" turboback
Old 05-09-2006, 10:19 AM   #37
cc4usmc
cc4usmc's Avatar
hmmm...so is it a legal swap or not?
Old 05-09-2006, 11:46 AM   #38
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Originally Posted by aznpoopy
i don't think it's as bad as most people assume. remember the LS1 may be bigger, but its an aluminum block. the ka24 is iron...
supposedly longblock + mani, flywheel, acc, etc weights look like this
sr ~ 330 lbs
ka ~ 370 lbs
ls ~ 390 lbs
QUOTE:
Weights:
KA with Auto, Cat and accessories = 596 lbs.
LS1 w/ T56, headers, and accessories = 468 lbs
That's right folks. The iron block four cylinder is 128 pounds heavier than the aluminum LS1!
Neejay is offline   Reply With Quote
Old 05-09-2006, 11:49 AM   #39
NemeGuero
No more nissan.
NemeGuero's Avatar
If you don't want to do a lot of work, don't get a KA-T.
Old 05-09-2006, 01:58 PM   #40
Neejay
Neejay's Avatar
QUOTE:
Weights:
That's right folks. The iron block four cylinder is 128 pounds heavier than the aluminum LS1! /QUOTE
Old 05-09-2006, 02:06 PM   #41
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I always thought its illegal to swap engines from another car make into another? Or is it legal as long as the engine is newer than the chassis and has all the smog equipment?
CLICK HERE!!!
Old 05-09-2006, 02:32 PM   #42
dannyboi
dannyboi's Avatar
dannyboi is making a name for him/her selfdannyboi is making a name for him/her self
Originally Posted by cc4usmc
I currently have a blacktop SR but im think of switching to KA-T because i will be stationed in SoCal (Camp Pendleton to be exact) at the end of the year. If it weren't for Cali's gay emissions i'd keep it. Now i want to know what you guys think. Keep the SR, or go KA-T? I'd also like to know the reasoning behind your answer. I know KA-T isn't legal either, but its easier to fix then an SR if a cop was to pop my hood and go . I'd rather not hear a bunch of "dont drive like an idiot and that wont have a reson to pull you over" etc. I just want to be prepared. Thanks Guys!
Tell the police you are fighting for this country and that you can do whatever the fuck you want.
dannyboi is offline   Reply With Quote
Old 05-09-2006, 02:47 PM   #43
aznpoopy
aznpoopy's Avatar
Originally Posted by Neejay
Weights:
that misleading
KA with auto = auto tranny still attached? vs. a LS1 with no trans? its probably more like 510 and 470.
still i agree the 'weight problem' is really people just making up excuses to hate the LS without any real info. a difference of 30 or 40 lbs is not a big deal
Old 05-09-2006, 03:05 PM   #44
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
That's correct. as long as the motor is newer than the car and it passes legal smog, the BAR ref will pass it. RX-7 guys have had their v8's legalized already
dude... it says with T56. That's the tranny code.
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 05-09-2006, 04:06 PM   #45
aznpoopy
aznpoopy's Avatar
lmao
well i learned something new today
Old 05-09-2006, 04:46 PM   #46
Neejay
Neejay's Avatar
lmao
Yeah, what he said (T56) LOL
Old 05-09-2006, 04:57 PM   #47
ALTRNTV
KA-T for the win, even though I'm going for SR.
ALTRNTV is offline   Reply With Quote
Old 05-09-2006, 05:04 PM   #48
Neejay
Neejay's Avatar
LIES!............
Old 05-09-2006, 08:29 PM   #49
fatalfury64
fatalfury64's Avatar
fatalfury64 can only hope to improve
what is the big deal with LS1? it ain't a genuine Nissan engine. would anyone call their 240 a Nissan anymore with an LS1 in it? Just my opinion.
fatalfury64 is offline   Reply With Quote
Old 05-09-2006, 09:00 PM   #50
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
like u said, both are illegal, both with get u screwed if they pop ur hood, and neither will pass visual checks at a smog station...
if u get a ref ticket just go pay the fine. thres some threads on here about what to do if u get a ref ticket. read up on em if u can find em.
i wouldnt worry about getting ur hood popped. if a cop finds out ur in the marine corps i doubt hes gonna treat u like a little punk off the street, HOPEFULLY hed have more respect than that.
but its true if you dont drive crazy, theres not much to worry about.
redsuns3838 is offline   Reply With Quote
Old 05-09-2006, 10:06 PM   #51
BigVinnie
BigVinnie's Avatar
Ref ticket and pay fine?
Thats only half of the problem. The other problem is having the car upto date on proper EPA/DOT regulations. If the car isn't fixed it can be impounded and sold at auction...... Some cars that are confiscated now in CALI are a manditory 30day impound if the officer feels that your car isn't safe for street driving.
Old 05-10-2006, 01:08 AM   #52
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Most of the local cops don't really care if your a Marine or not.
Jung918 is offline   Reply With Quote
Old 05-10-2006, 01:29 AM   #53
fliprayzin240sx
Most cops dont like marines unless theyre prior marines...
But anyways thats another point. Keep your out of state plates. Any plates is better than california plates thats for sure. Non-cali plates...no cali jurisdiction period. They can try to force you to pay fines or wut not but they cant do shiet to your car period.
CLICK HERE!!!
Old 05-10-2006, 01:35 AM   #54
EchoOfSilence
who gives a shit if you can't call a 240 a 'Nissan.' It was still made by them, right?
This isn't a car to be a purist about. It's all about personal preference.
Old 05-10-2006, 02:46 AM   #55
Id-
Id-'s Avatar
It has HUGE aftermarket; can make far more power than the SR or KA can; especially on pumpgas.
400whp and 400ft-lbs of torque with a HUGE powerband and tons of torque off the line is doable with a simple intake manifold, cam swap, and head porting. Drivability, gas mileage, responsiveness, etc... the list goes on. The swap is legal, provided the engine is swapped into an older car (not hard since most LS1s are 1998+)
The transmission won't shit a brick when you go to higher power levels either. The Tremec T56 is HUGE. Weighs double the KA tranny.
The 1jz isnt a legal swap either. It has no provisions for EGR, etc. It was never available in a USDM vehicle.
-DD pimp car
-GTIR T28
-Big FMIC
-RPS Max clutch
-3" turboback
Old 05-10-2006, 06:33 PM   #56
Slo S14
Slo S14 is an unknown quantity at this point
Send a message via AIM to Slo S14
So let me get this straight, a drifter uses an Ls1 so all of the sudden its the new fad?
Stockish' base model S14
Slo S14 is offline   Reply With Quote
Old 05-10-2006, 07:09 PM   #57
BigVinnie
BigVinnie's Avatar
Well not to argue but to some people it is about being a purist. As for me I've owned nothing but Nissans. Owned a Datsun 510, 240sx, hardbody, and then a 2004 frontier. Some people just like the nestalgia and respect that comes with the badges and logo's that comes with the vehicle, and then again there are those that don't give a fuck....
Half the people that buy Nissans don't even know that they built the kamikazi fighter jets that fought against us in world war 2.... So to some they don't know enough about where or who our own enemies were.
I'm a purist because I respect the technology that comes with Nissan. I respect chevy because they build great powerful trucks at an affordable price, thats about it....
Old 05-10-2006, 07:13 PM   #58
EchoOfSilence
Actually, it was Mitsubishi that built the Zeros.
Anyway... don't get me wrong; I like what Nissan used to be, and Nissan later may be great. But I do believe there are better manufacturers out there. I say that this car isn't one to be a purist about because it doesn't have as extensive of a history as other cars do (although it does have some race history). Instead, most of its background is based around its use in a sport where anything goes.
Give me a 510, a 240z, a Skyline, an M3, a Porsche..... etc. Those are better candidates, in my opinion, to be a purist about (if you'd like).
However we're going off on another tangent.
I like both motors, however I've never been in a nicely running tuned KA-T (Evan )
Old 05-10-2006, 07:19 PM   #59
BigVinnie
BigVinnie's Avatar
What huge power band, the rev and redline is about as consistent as the KA's on boost. It will drop out before 7000RPM. Now if you talk about the z06 vette Ls7 now you have an engine that far surpasses the power band of the sr on any level with a higher peaking redline as well. LS1 is small potatoes as far as rev and redline is concerned.
Old 05-10-2006, 07:27 PM   #60
BigVinnie
BigVinnie's Avatar
Read the history of prince motors/Nissan
http://zhome.com/History/Truth/Prince.htm
