Old 03-18-2005, 04:15 PM   #1
Dream240
Dream240's Avatar
OBX shifter woes (I searched)
Okay, I finally decided to put the OBX SS in my tranny that's sitting in my garage. I pulled the old one out and looked at the two only to notice that the OBX shifter's bottom piece, the piece below the ball, is longer than the stock one. Thus when I install the OBX shifter, it hits inside the tranny and won't allow me re-attach the shifter plate. WTF!! Did I get the wrong shifter? Since the guy I bought it from didn't include the instructions, i'm starting to think I'm missing some parts. The only parts that came with it are a couple of balck brackets, some bolts, and what looks like a custom shifter cover plate. I dunno. Does someone have some instructions they can scan for me? Their website and web support is a joke. No replies. Anyone help!!
Also I'm using the stock shifter mounting piece, the piece that the ball of the shifter sits in. Is this right? Am I missing some parts?
Old 03-18-2005, 04:19 PM   #2
Andrew Bohan
CONSOLE REMOVAL:
1) Remove the shift knob (twists off c-clockwise)
2) remove the console- (includes leather boot). It simply pulls off--It is held on by spring tentioned clips.
REMOVAL OF OEM SHIFT LEVER--AS WELL AS PREPARING FOR PM INSTALL
1) Uncrew 4 10mm bolts retaining the OUTER BOOT(#10) and remove the OUTER BOOT.
2)Cut the Zip Ties that are securing the DUST BOOT(#8) and turn over the boot from the bottom side so you can access what is under it.
3)Remove the SNAP RING(#11) using snap ring pliers or a good set of needle nose, and pull out the OEM shift lever. (the snap ring will not be re-installed---this doesn't mean destroy it trying to remove it!)
4)Remove the C_RING(#12) using any tools you deem necessary--(the c-ring will not be re-installed---this doesn't mean destroy it trying to remove it!)
5)Pull out the BUSH SOCKET(#13) from the CONTROL COVER(#15). (removed part will be re-used---so be careful)
6)Remove the WAVE WASHER(#14)fromt he CONTROL COVER(removed part will be re-used---so be careful)
INSTALLATION OF THE PM SHIFT LEVER
1)Place the COLLAR(#2) in the bottom control cover (where the BUSH SOCKET WAS)
2)Place the WAVE WASHER on top of the COLLAR
3)Place the BUSH SOCKET on top of the WAVE WASHER
4)Place the GASKET(#4) on the control cover (this will surround the recently installed BUSH SOCKET, WAVE WASHER, AND COLLAR. It will not touch any of these pieces.
5)Insert the PM SHIFTER(#1) until the PM SHIFTER'S ball rests on the BUSH SOCKET, making sure that the small plastic bushing at the bottom of the PM SHIFTER enters the similarly sized hole in the transmision (in the control cover hole--at the bottom)
6)Secure the SPACER(#3) TO THE CONTROL COVER using the the PLATE NUTS(#7), CAP BOLTS(#5), and WASHER(#6).
Here's how the PLATE NUTS attatch to the spacer.
Here's the easiest way I have to expalain it. If you took the Plate nuts and place the PLATE NUTS face down (nut-side facing down). Place them so the nuts mimick the bolt pattern on the spacer. For ease of installing, fasten (partially) 1 of the 2 bolts on each of the PLATE NUTS. ovbiously using the CAP BOLTS AND WASHERS. next place the SPACER/PLATE NUT assembly on the CONTROL COVER (put shift lever through SPACER's hole). Next swing the PLATE NUT so they are resting in the groove in the CONTROL COVER (this grouve was originally where the bottom lip of the DUST BOOT was secured. The nut side should face down, making the side facing up the smooth side with no nuts protruding
9) Insert the remaining (2) CAP BOLTS and WASHERS and securly fasten the cap. After fastening, check to make sure shifter moves smothely (overtightening will cause un-smooth shiftlever movement).
10)Slip the DUST BOOT (the one that came with the PM shifter) over the top (shift knob side) until the narrow end of the DUST BOOT clears the fat part of the PM lever. Use some lubricant (I used Vaseline) to assist in sliding the boot over the fat shift-lever---It is not easy to streatch the boot that wide---be careful!).
11) Secure the TIE STRAPS Supplied by PM over the top (narrow) and bottom (fat) side of the dust boot (like it was on the oem shifter.
12)Re-install the RUBER BOOT
13)Re-install the Consol
Old 03-18-2005, 04:46 PM   #3
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
damn the B&M was WAY easier to install. Well worth the money.
DJPimpFlex is offline   Reply With Quote
Old 03-18-2005, 05:51 PM   #4
Dream240
Dream240's Avatar
Ah....I see. i wasn't disassembling the socket piece. I was trying to install the shifter right into it. Cool thanks Driftaholic great instructions.
Old 03-21-2005, 12:27 AM   #5
raging panda
raging panda is an unknown quantity at this point
Send a message via Yahoo to raging panda
ive installed 2 obx shifters so far, and i really like them and so does my buddy who has the other. I dont see why so many people diss on them, they work great as long as you install them right.
raging panda is offline   Reply With Quote
Old 03-21-2005, 07:20 AM   #6
s14srpilot
s14srpilot's Avatar
s14srpilot is an unknown quantity at this point
Send a message via AIM to s14srpilot
True. If you install it correctly it will work just fine. Until either: 1. The shifter comes apart and you gotta glue it back together (Complete turn off and immediate awareness of cheap quality), or 2. You drive a car with a B&M short shifter. In the 2nd case you will immediately want the B&M because it feels 10 times better.
s14srpilot is offline   Reply With Quote
Old 03-21-2005, 11:52 AM   #7
Dream240
Dream240's Avatar
So in instance no 1, wouldn't you just use loc-tite on the threads and never have that problem? Also here's a question....what do you do about the dust boot, since the OEM one on the OEM shifter doesn't seem like it will come off without destroying it, and there's wasn't one included with the one I bought....should I just order a new one from nissan?
Old 05-19-2006, 04:59 AM   #8
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
so from that instructions does a shifter boot come with the obx model? im missing mine and my car smells like crap do you guys think i can make one?
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 05-19-2006, 07:18 AM   #9
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
B&M was way to short for my personal feel. I like short shifters to feel like thats how they should have been from the factory. I dont want it to feel like I have a short shifter.
Its like people who put short shifters on M3's, rx7's, Miatas...They allready feel damn good! Dont go butcherin it up by making each gear 1/64 of an inch apart
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
