Old 06-09-2002, 07:17 AM   #1
92N240SX
92N240SX is an unknown quantity at this point
Just wondering which ones to get that perform the best on the 240 engine, for a reasonable price of course im not looking to spend 30 on plugs.  thanks
92N240SX is offline   Reply With Quote
Old 06-09-2002, 07:20 AM   #2
vicki240sx
vicki240sx is an unknown quantity at this point
I have NGK. I am told they are the best. They are about 3 bucks each for the copper ones.. not sure bout the platinums but they were a lot more exp.
nani iro no panties desu ka?
i do not intend to tip toe through life just to sneak up on death
vicki240sx is offline   Reply With Quote
Old 06-09-2002, 08:07 AM   #3
guidot
guidot is an unknown quantity at this point
Send a message via AIM to guidot
PLATINUM ONLY!  Please read your owners manual.  That is NOT a suggestion!  If you can't afford the NGK Plat V-Power (Autozone) or the NGK Plat R's (dealer), get the Denso Platinums.  They are the same thing.  I have had the Denso's in for 10000mi and they are fantastic; no problems at all!
NGK-R's = $3-4 each
NGK-V's = $2-3 each
Denso's = $2-3 each
depending on availablity
-Jeff T. 96 240SX
240SXONE
http://www.240sxone.com
guidot is offline   Reply With Quote
Old 06-09-2002, 09:58 AM   #4
vicki240sx
eeek I did not know that. My bro has a lude and he uses copper ones instead of platinum.. so I figured it would be the same for my car. When I bought the car it didn't come with the owners manual.  Are bosch platinums good as well?
Old 06-09-2002, 10:36 AM   #5
gh6o6
gh6o6 is an unknown quantity at this point
i got the bosch platnums in my car - they seem to work fine
gh6o6 is offline   Reply With Quote
Old 06-09-2002, 06:16 PM   #6
240sxygrl
240sxygrl is an unknown quantity at this point
I use NGK Vs on my s13.....214K on original motor. Still runs like a champ.
240sxygrl is offline   Reply With Quote
Old 06-09-2002, 09:48 PM   #7
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (guidot @ June 09 2002,10:07)</td></tr><tr><td id="QUOTE">PLATINUM ONLY! Please read your owners manual. That is NOT a suggestion! If you can't afford the NGK Plat V-Power (Autozone) or the NGK Plat R's (dealer), get the Denso Platinums. They are the same thing. I have had the Denso's in for 10000mi and they are fantastic; no problems at all!
NGK-R's = $3-4 each
NGK-V's = $2-3 each
Denso's = $2-3 each
depending on availablity</td></tr></table><span id='postcolor'>
thats only for s14's. &nbsp;S13's recommned copper plugs. &nbsp;
Actually copper plugs are better for performance, platinum is just for extended life of the plug.. &nbsp;Putting platinum plugs in a car is one reason why so many new car company's have 100,000 miles till first tune up
Old 06-09-2002, 10:12 PM   #8
guidot
So why would they recommend different plugs for the same engine? &nbsp;Thats a bit baffling.
-Jeff T. 96 240SX
240SXONE
Old 06-10-2002, 04:43 PM   #9
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (guidot @ June 10 2002,12:12)</td></tr><tr><td id="QUOTE">So why would they recommend different plugs for the same engine? Thats a bit baffling.</td></tr></table><span id='postcolor'>
It's not the exact same engine. &nbsp;Different cams, different pistons, and like I said. &nbsp;It's kind of a marketing ploy... &nbsp;Platinum and iridium plugs just last longer. &nbsp;they don't spark better.
Old 06-10-2002, 11:50 PM   #10
misnomer
misnomer's Avatar
NGK VPowers are what I run in my s13, folks at Car Quest looked it up and said those were the ones <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''> Copper iirc, cost me about four bucks for all of them.
Old 06-11-2002, 12:33 AM   #11
rotaryknight
rotaryknight is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ June 10 2002,5:43)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (guidot @ June 10 2002,12:12)</td></tr><tr><td id="QUOTE">So why would they recommend different plugs for the same engine? Thats a bit baffling.</td></tr></table><span id='postcolor'>
It's not the exact same engine. Different cams, different pistons, and like I said. It's kind of a marketing ploy... Platinum and iridium plugs just last longer. they don't spark better.</td></tr></table><span id='postcolor'>
Yep Platinum suck. &nbsp;Mazda recommends Plats on the FD but they don't perform for crap the only reason is that rotaries foul plugs like every 1500 miles so most guys use plats to not have to change them. &nbsp;The guys that tend to be more performance based tend to use the non plats and just change them all the time.
Iridium actually does work well. But for a rotary they are $35 ea. retail so no one really wants to change those. &nbsp;I have a couple friends that used them for track events then take the plugs out as soon as they are done and save them for the next event.
HKS Iridium plugs for the 240sx are not that bad but Nippon Denso makes them for HKS anyways(except for the rotary plugs which ND makes for HKS but does not sell on their own label) so just get the ND ones.
Daily Driver- 91 240 SX SE...S13 Blacktop
HKS FMIC, EVC IV, W/G, Racing Suction, DP, Dual Drager, springs/pillow ball mounts
Whiteline sway bars
Tokico blues
Koyo Radiator, Fluidyne fan
J30 VLSD
stock exterior.
Fun Car- 94 FD3S (TO4S). The White HKS FD in FnF......may she rest in pieces.
rotaryknight is offline   Reply With Quote
Old 06-11-2002, 08:20 AM   #12
sykikchimp
WOW addicted
sykikchimp's Avatar
NGK makes iridium plugs now too.
