![]() Join Date: Dec 2002
S13 wiring mystery...
Ok I have a 89 chassis with a DE swapped into it already (dont know the year or the harness or ecu, but it is from a s13). Everything seems to work for the most part. The question i have is on the Main harness connctor (M53) to the EFI harness connector (F1). I thought that the 91-94 wiring was the same but ive seen 2 different pinouts for the connectors. Its all the same but with 1 pin being different.
G=GREEN R=RED B=BLACK W=WHITE Y=YELLOW L=BLUE O=ORANGE 91 G/R XX B XX XX XX R XX G/W XX G/Y L/G G/B Y/G G Y/R O XX 93 XX XX B XX XX XX R XX G/W XX G/Y L/G G/B Y/G G Y/R O XX what i have G/R XX B XX XX XX R XX G/W XX G/Y L/G G/B Y/G G Y/R O L/B B is ground R pin 24 on ecu G/W is CLK for ecu G/Y pin 44 on ECU (says to the defogger relay but in that schematic G/Y goes to the timer contr.) G/B is RX for ecu G is TX for ecu O is +12v L/G pin 41 on the ECU (says goes to Thermo Contr AMP, but in that schematic its not there) Y/G is for the speedo Y/R is for the tach G/R goes to pin 23 of the ecu and the consult connector, ive seen it referenced as CHK. L/B does not go to the ECU and i have no idea what it does. Ayone have any ideas at all???? I really dont want to hand trace all the wires out to find out what they go to. Now for the 89 side of the house i cant find a full diagram, i have ones for componants. The full diagram i have says its for a 200sx and the wire colors it lists dont match to what i have, plus i have 2 more than are in the diagram Here is what i have R/Y G/L Light G Purple G Grey B L/G Y/G Y/R L/B R O Can anyone figure this out? |
