Old 06-19-2006, 10:20 AM   #1
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
RUCA quick question.
Going adjustable and the bolts on my car aren't in the best of shape. So, keep the adjustable camber bolt or ditch it? I'm leaning towards ditching it but wanna make sure I'm not screwing myself by doing so. Thanks
Old 06-19-2006, 11:42 AM   #2
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
do not listen to brian
http://bhworld.wordpress.com/
Old 06-19-2006, 12:43 PM   #3
projectRDM
projectRDM's Avatar
But you will need a large fender washer on either end to keep the bolt located in the slot, otherwise it will slide under load.
Old 06-19-2006, 12:45 PM   #4
Dousan_PG
Dousan_PG's Avatar
nooo
keep them
they subframe is slotted
under drifting/hard driving/road race etc etc etc
the replacement bolt will slip
the eccentric bolt will keep the ruca from moving on the subframe side
def keep it!
i removed mine ages ago (when i first got rucas on my s13)
it went from a good alignment -2.5 rear camber...to...
-4.5 and retarded toe in!
hahahha
KEEP IT!!
Aaron
Pink GodziRa
Old 06-19-2006, 01:44 PM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
I was going to use another regular suspension bolt (they're all about the same).
Thanks Aaron, figured someone here would've already tried it and give feedback. So they'll stay on. Rep for all (even you Brian) that took the time to respond.
/lock
Old 06-19-2006, 02:40 PM   #6
projectRDM
projectRDM's Avatar
A regular bolt and a pair of large washers is a MUCH better solution than keeping the OE eccentric bolt in place. The OE bolt can still be adjusted by someone, throwing off your alignment, and typically the washer will jam into the bolt and keep it from coming off easily if it's needed. Plus if you do remove it for maintainence, etc. there's no gaurantee you'll get it back exactly to where it was, whereas a regular bolt can only sit in one spot if installed correctly.
