Old 06-22-2006, 09:49 PM   #2
OdessaS13
OdessaS13's Avatar
OdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the rough
Send a message via ICQ to OdessaS13
you had hard time closing cover because the fuel o-ring expand when it got exposed to air, get a new one from nissan 16$. the walbro is shorter then the stock pump but its still suppose to sit at the lowest point of the bracket, did you insert the rubber piece between the pump and the bracket? if the filter is hitting the bottom then your doing something wrong, reckeck and reinstall, and use zipties to hold the pump.
PS use heatshrink were you solder the connections from the walbro to the stock wires, electrical tape disolves in gas as i found out lol
OdessaS13 is offline   Reply With Quote
