Old 06-26-2006, 11:20 PM   #1
wutangben
wutangben is making a name for him/her selfwutangben is making a name for him/her self
Send a message via AIM to wutangben
Originally Posted by ou1848
take the injector and rotate it 180degrees. Then take a wide tip flat screwdriver and stick it between the rail and the ride on the injectore. Pry up about 5mm and the thing will pop out. You will likely need new o-rings
m
the purple plastic just breaks away... also will they only come out at 180 degrees?
wutangben is offline   Reply With Quote
