Old 06-27-2006, 07:01 PM   #1
reverend_sean
reverend_sean's Avatar
reverend_sean is an unknown quantity at this point
Thermostat help, just changed coolant, overheating now
So I just changed the coolant in my restop s13. I followed the flush, refill, run, flush, refill, run method with distilled water until it came out clean. every time I would let the car heat up until the thermostat opened and water flowed through the block. I did that 3 times and each time the water became more and more clear until it was clean. So I figured out what a 70/30 water to coolant solution (plus 6 ounces of Water Wetter) is for the 7 liter system (2.1L coolant) and poured the coolant/Water Wetter mix into the radiator, because the block was already full of distilled water, and then I would top off with water till it was full after running it. I started it up to run the solution through the car and now it seems like the thermostat will not open and the car is over heating!!!!!! It seems like it is running in limp mode because it will not rev correctly, but I have never experienced limp mode before so I don't know for sure. the 3 times I drained, flushed, filled the radiator for the last hour it opened every time, now all of a sudden it doesn't want to open?!?! Can anyone offer insight? I searched, coolant, thermostat, radiator and didn't really find anything that seemed to help. Thanks!!
'89 S13
reverend_sean is offline   Reply With Quote
Old 06-27-2006, 08:10 PM   #2
reverend_sean
I have no idea why this happened. I let the car cool down for 30-45 minutes. started it back up, and now the thermostat opens again and the engine revs freely.
'89 S13
Old 06-27-2006, 08:38 PM   #3
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
Just be sure you get ALL the air bubbles out. Did you jack up the front of the car as high as you could and use the bleeder screw?
SpeedMonkeyInc is offline   Reply With Quote
Old 06-27-2006, 08:46 PM   #4
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
+1^^^ You need to bleed the coolent system. There is a 10mm screw on top of the intake manni. with a little yellow sticker that says not to open when hot. That is the bleeder.
NIK90s13 is offline   Reply With Quote
Old 06-27-2006, 09:21 PM   #5
reverend_sean
Thanks a ton, I missed that point some how. I haven't driven the car yet, I will jack it up first thing tomarrow and bleed it. I have never noticed that screw before!?
'89 S13
Old 06-27-2006, 09:33 PM   #6
reverend_sean
So you bleed it with the car running and once water starts coming out of the hole there is no more air right?
'89 S13
Old 06-27-2006, 09:49 PM   #7
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
^^ That's what I always thought.
also, any remote possibilities of the Coolant temp sensor going bad?
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 06-28-2006, 06:17 AM   #8
NIK90s13
NIK90s13's Avatar
The car does not need to be running. I do it with the car off, the water pump will pump water out if it is running. Raise the car slightly, pull the bleeder and washer, fill with coolent till it comes out of the bleeder, cap it back off, put thr rad cap back on, run the car, repeat if nessary.
Old 06-28-2006, 07:34 AM   #9
reverend_sean
As soon as I poped it open, coolant just started pouring out so I think I am all set. BTW, the bleeder is on the thermostat housing not the intake manifold. I knew I had seen it before, but could n't remember where to look!
'89 S13
Old 06-28-2006, 07:08 PM   #10
kandyflip445
kandyflip445's Avatar
I don't know about the SOHC but on the DOHC it's on the manifold. I would make sure it's well bled from that point and then top it off if needed when you lower the front back down.
My 240 vBgarage
Old 06-29-2006, 12:43 PM   #11
Frenzy13
Frenzy13 is an unknown quantity at this point
Send a message via AIM to Frenzy13 Send a message via Yahoo to Frenzy13
^^^ He said he has a redtop... so he's got an SR not a KA.
1992 240SX SE - Goodbye...
1997 240SX - At last I have one...
Frenzy13 is offline   Reply With Quote
