Old 02-07-2002, 03:07 AM   #1
boOmbaa
boOmbaa is an unknown quantity at this point
I just got a momo shift knob w/o the boot ($$$) and its alot shorter than the factory one.  Now I got this BiG uGly space between the shift knob and the boot.. i tried screwing it into the knob but it just falls down when i shift.. is there anything can do bout it or did you gotta buy the momo boot too and would any boot fit on the momo?!  all advice appreeciated!**)
boOmbaa is offline   Reply With Quote
Old 02-07-2002, 03:58 AM   #2
Archangel
Archangel's Avatar
Archangel is an unknown quantity at this point
Send a message via AIM to Archangel
My freind got a Momo knob on his prelude and he has the same problem.  He hasn't done anything about it though.
I'd imagine any boot would work, don't see why it wouldnt.
Archangel is offline   Reply With Quote
Old 02-07-2002, 07:11 AM   #3
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
The ring on the bottom of your shiftknob should be touching your shift boot (that is if your shift boot is pretty new). Momo boots are only $50 or so... a little bit more than other boots.
I used to have that space on my old 240... I just put hair scrunchies over it. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> But I'm a girl... I can do that...
S13Grl is offline   Reply With Quote
Old 02-07-2002, 07:13 AM   #4
S13Grl
Married to the Mob
S13Grl's Avatar
P.S. I had to use the scrunchies until I got the Momo one. You can buy any aftermarket boot, some of them have a tightener at the top. (usually a string...)
Old 02-07-2002, 09:05 AM   #5
yenpit
yenpit is an unknown quantity at this point
the Momo boot attaches to the knob, 2 diff versions of boot: one req's additional collar, other has a threaded collar inside the boot and screws to the knob. easy install as long as u dont trim it too short! the cheap aftermarket boots work ok and stand &quot;tall&quot; like S13grl said, but no &quot;clean&quot; way to attach to Momo knob, it would eventually settle and fall like OE......but Momo is SWEEEEETTT!!!
yenpit is offline   Reply With Quote
Old 02-07-2002, 09:23 AM   #6
WhiteS13
WhiteS13 is an unknown quantity at this point
Send a message via ICQ to WhiteS13
There's a Momo finisher piece that you can get which screws onto the bottom of the knob. It has a ring on the bottom where you can slip the momo boot on and eliminate that gap.
Momo makes 2 universal boots. &nbsp;One is longer.
I had one on my Prelude because I couldn't bear with the gap. Got rid of the knob and boot, and replaced it with a Integra Type-R titanium shifter and factory leather boot with red stitching instead. It gets cold, but I don't drive the car in the winter anyways.
(Edited by WhiteS13 at 4:41 am on Feb. 7, 2002)
WhiteS13 is offline   Reply With Quote
Old 02-07-2002, 10:25 AM   #7
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
i have a leather momo shift knob, and my ring on the bottom won't fit, i don't have enough room to screw it in, so... shucks...
240meowth is offline   Reply With Quote
Old 02-07-2002, 01:15 PM   #8
tnord
tnord's Avatar
tnord is an unknown quantity at this point
uhhh.........i have a knob that when i initially put it on created the same gap, but all you have to do is take the boot out, make it as tall as you can then put it back on, it's not tight, but the boot stays up right under the knob, there is plenty of material there, it's just all scrunched down
tnord is offline   Reply With Quote
