Old 07-11-2006, 10:33 AM   #1
Serebros
Serebros's Avatar
Serebros is on the path to ruinSerebros is on the path to ruinSerebros is on the path to ruin
Send a message via AIM to Serebros
Arrow Is 300zx Rear Brake Swap Worth It?
i already have the whole front, and for the rear i have the calipers and the ebrake assemblys, i was wondering if it was worth doing it? the rear i mean, and im not drifting so i dont care about the drum ebrake, i asked some guys and they said the 300zx rears barely had an advantage if any? what u guys think? any of u guys driven just fronts and drive all 4's, does it feel any different
Horsepower Sells Cars, Torque Wins Races - Carrol Shelby
Serebros is offline   Reply With Quote
Old 07-11-2006, 10:38 AM   #2
Nostradamus
Nostradamus's Avatar
Nostradamus will become famous soon enoughNostradamus will become famous soon enoughNostradamus will become famous soon enoughNostradamus will become famous soon enoughNostradamus will become famous soon enough
z32 fronts and stock rears feel perfect to me.
Nostradamus is offline   Reply With Quote
Old 07-11-2006, 11:13 AM   #3
HyperTek
if you do the rears you gotta swap the brake master cylinder to any z32 *they all got different ratios * of your liking. just a little more involved swap. But i have it, the brake pedal feel is really nice, firm and tight like a new car. I dont like the drum ebrake tho, its just not as simple as the stock rear calipers.
If you like simplicity, stick with the stock rears and put in some good brake pads.
Keep it Classy
Old 07-11-2006, 11:18 AM   #4
cgguy
cgguy's Avatar
cgguy is on a distinguished road
It all depends on what you plan on using the car for. If it's only a daily driver then there's no real performance advantage gained from swapping anything...fronts included. If you're not working the brakes hard enough to induce lock-up or fade then having extra pistons doesn't make a difference.
There's an argument to be made that while only swapping fronts you're creating a bias issue with the brake system. This has been covered a LOT of times and a search will provide any answers on the topic. And should you decide to do the rears then you'd better think about replacing the master cylinder.
That all said, I have only done my fronts and aside from the brake pedel being slightly spongy I don't think I'm missing out on anything not having z32 rears. If you plan on tracking the car hard or just want shit to look cool then by all means do the rears too. You've already got most of the parts needed.
cgguy is offline   Reply With Quote
Old 07-11-2006, 11:25 AM   #5
Dousan_PG
Dousan_PG's Avatar
if you have it/had it etc
then YES
if you havent, then no
because your content w/ what you already have
but w/ the full swap its night and day. braking pedal feel as well as the enjoyment of after lapping around the track pulling your ebrake intead of finding boards for your car. and if u drift, ebrake slides and such are so easy. locks up so fast. its really a pleasure.
DO IT if you have the money and time. otherwise, stick w/ stockers.
Aaron
Pink GodziRa
Old 07-11-2006, 11:33 AM   #6
Serebros
Serebros's Avatar
i already have a z32 mc, i was gonna use it regardless, my primary goal is autocross, scca solo, in that veiw are the rears worth it? performance wise
basically is the full swap noticeably different than just the fronts (both with z32 mc)?
Old 07-11-2006, 11:51 AM   #7
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
I wouldn't say, if in reference to initial bite, that you'd feel a noticeable difference, but insofar as heat dissipation and brake balance are concerned (especially during road racing)... go for it.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 07-11-2006, 12:14 PM   #8
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
I would agree w/ Tek and Dousan.
Only this I have to admit, I would run both only to keep a perfromance balance to the car.
_Quality ain't cheap. .. . it pertains to the dreams of your better half.
so choose what you think will satisfy your better half Main.
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
