Old 07-30-2006, 05:04 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
intake question 97 s14 with ka
my question is this.
the intake air temp sensor..where does the plug that goes to that plug in on an aftermarket intake, such as an aem?
thanks in advance.
-devon
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 07-30-2006, 05:06 PM   #2
nightkid86
nightkid86's Avatar
nightkid86 is just really nicenightkid86 is just really nicenightkid86 is just really nicenightkid86 is just really nicenightkid86 is just really nicenightkid86 is just really nicenightkid86 is just really nicenightkid86 is just really nicenightkid86 is just really nice
Most people just let that sensor dangle, it's not important - the temperature isn't going to be that different inside or outside the tube.
nightkid86 is offline   Reply With Quote
Old 07-30-2006, 05:08 PM   #3
devonkyle77
but it throws check engine light, right?
Old 07-30-2006, 05:09 PM   #4
nightkid86
nightkid86's Avatar
No, it is just a temperature sensor. Most people keep the sensor connected and just move it out of the way not plumbed into anything. You won't get CEL
Old 07-30-2006, 05:12 PM   #5
devonkyle77
but will get a cel if u remove the sensor entirely, ya?
Old 07-30-2006, 06:09 PM   #6
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
probably...
usuaslly if you get the right intake it comes with the maf adapter where you can plug in the intake temp sensor... there was a revision on the OBDII models iirc that companies did take into account so you have to make sure you get the right kit.
if not, you can just put the sensor inside the air filter where the maf adapter is and just have it dangle inside there.
Sfourteen
dct223 is offline   Reply With Quote
Old 07-30-2006, 06:16 PM   #7
trsilvias13
apexi sell the intake with the sensor, I have one.
If you unplug it, you will get a CEL. That happen to me. I never thought about just letting it dangling with the censor. If so I would just relocated it somewhere else
Old 07-30-2006, 08:03 PM   #8
projectRDM
projectRDM's Avatar
An intake designed for a Kouki will have a grommet for it. If not, drill a hole, fit the OE grommet, then fit the sensor.
But as noted it can be left hanging with no ill effects, it's only used for diagnostics and could care less what the reading is as long as it sees one.
Old 07-31-2006, 12:04 AM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Or another thing that i did when i had my KA was get rid of the sensor all together and slip a resistor on the plug. Just cant remember what the ohmage was.
CLICK HERE!!!
Old 08-01-2006, 10:22 PM   #10
devonkyle77
my sensor is MISSING and needs replaced. courtesy said they have two results for the same thing,. a metal one 22630 - 44b20 and a plastic one 22630 -1s700
how do i know which is right?
Old 08-02-2006, 08:55 AM   #11
projectRDM
projectRDM's Avatar
97-98s are all plastic.
Old 08-02-2006, 03:42 PM   #12
cgguy
cgguy's Avatar
cgguy is on a distinguished road
It's kind of a late post to the thread but this link should clear some things up for you:
http://www.240sx.org/links/installs/...take/index.htm
cgguy is offline   Reply With Quote
Old 08-07-2006, 11:57 AM   #13
vspec15
vspec15 is making his/her stupidity well-knownvspec15 is making his/her stupidity well-knownvspec15 is making his/her stupidity well-knownvspec15 is making his/her stupidity well-knownvspec15 is making his/her stupidity well-known
does having an aftermaret CAI affect the CEL or cause smog issues?
vspec15 is offline   Reply With Quote
Old 08-07-2006, 01:07 PM   #14
orion::S14
orion::S14's Avatar
If you install it correctl, you'll get no CEL.
As for smog issues...you'll pass the sniffer just fine, but if there's no CARB #...I'd guess you'll fail some visual inspection, but the CA guys need to chime in if that's what you're asking.
- Brian
www.KA24DEvelopment.com
