Old 08-04-2006, 08:08 PM   #3
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
tension rods are adjusted to stock length
tie rod ends are adjusted to stock ball joint length and I have the threads measured correctly on the rod itself.
thanks for the info, i was just more or less worried if adjusting it off the ground would be any different than adjusting things on the ground
sean350z is offline   Reply With Quote
