intake question 97 s14 with ka
my question is this.
the intake air temp sensor..where does the plug that goes to that plug in on an aftermarket intake, such as an aem? thanks in advance. -devon
WTB-NARDI wheel & NRG 2.8 QR |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
probably...
usuaslly if you get the right intake it comes with the maf adapter where you can plug in the intake temp sensor... there was a revision on the OBDII models iirc that companies did take into account so you have to make sure you get the right kit. if not, you can just put the sensor inside the air filter where the maf adapter is and just have it dangle inside there.
Sfourteen |
apexi sell the intake with the sensor, I have one.
If you unplug it, you will get a CEL. That happen to me. I never thought about just letting it dangling with the censor. If so I would just relocated it somewhere else |
![]() Join Date: Dec 2002
An intake designed for a Kouki will have a grommet for it. If not, drill a hole, fit the OE grommet, then fit the sensor.
But as noted it can be left hanging with no ill effects, it's only used for diagnostics and could care less what the reading is as long as it sees one. |
Man w/ CTSV & a Car Seat
Or another thing that i did when i had my KA was get rid of the sensor all together and slip a resistor on the plug. Just cant remember what the ohmage was.
my sensor is MISSING and needs replaced. courtesy said they have two results for the same thing,. a metal one 22630 - 44b20 and a plastic one 22630 -1s700
how do i know which is right?
It's kind of a late post to the thread but this link should clear some things up for you:
http://www.240sx.org/links/installs/...take/index.htm |
#14 | |
![]() Join Date: May 2003
As for smog issues...you'll pass the sniffer just fine, but if there's no CARB #...I'd guess you'll fail some visual inspection, but the CA guys need to chime in if that's what you're asking. - Brian
www.KA24DEvelopment.com |
