Old 10-03-2006, 05:38 AM   #10
JohnC
JohnC's Avatar
JohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of light
Those values are just to fill the equation, as I stated in my post.
You input whatever value you want to get the calculated correction value.
If you set LOW at 30% throttle (yellow) , put 30 in that field. If your correction value (green)
for LOW setting is 15 enter that value in the field.
Same for High.
Throttle Position Percentage is to enter the % at which your throttle will be.
All this info , enetred into the equation, will output the correction value
for the given throttle position percentage according the the values enterd
in the hi and low fields.
JY Racing LTD.
JohnC is offline   Reply With Quote
