Old 07-08-2002, 05:12 PM   #1
YellwMonky
YellwMonky's Avatar
YellwMonky is an unknown quantity at this point
Okay, well i was driving home the other day and noticed that my car is a LOT louder than normal <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''>. It sounds like the fan is a lot louder and much deeper. That's between 2 and 3k rpm that my fan sounds really loud. Then all of a sudden after 3k rpm it starts to let out a real loud squeal <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cry.gif" border="0" valign="absmiddle" alt=''> . I've opened up the hood but i dont see anything visually that can be scraping. Any ideas on what to do ? The squael is driving me nuts. I can even hear it through my music
s13 92 White 240sx SE Coupe
YellwMonky is offline   Reply With Quote
Old 07-08-2002, 07:41 PM   #2
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
Im not sure about ur fan troubles, but i have a belt squeal that always happens at about 4k+, if u have what i have, u can use belt dressing as a temporary solution, but u would need to either have the belts tightened, or check them for possible replacement, i think someone told me that they found the alternator belt was the cause for their squeal. &nbsp;
hope that helps
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 07-08-2002, 10:32 PM   #3
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
(FYI)
Sometimes if one of the pulleys is slightly crooked...it will chirp or squeal. &nbsp;This happend to my sisters car before after she got into a wreck, one of the brackets holding the alternator was bent...and the lip of the belt rubbed the belt wheels (pulley wheels..or whatever they are called). &nbsp;The cheapest way to get it fixed is to goto Autozone or something...and ask one of the clerks to come look at it...and they might be able to tighten something for you (if need be).
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 07-18-2002, 10:48 PM   #4
jarnld
jarnld is an unknown quantity at this point
new belt, or tighten it up...not too expensive part wise...my rx7 did that too except only in first gear.
there is a barber in town that shaves only people who do not shave themselves. &nbsp;Does he shave himself? &nbsp; think about it...
jarnld is offline   Reply With Quote
Old 07-18-2002, 11:07 PM   #5
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
actually you wouldnt need to tighten up your belt. if its squeling its toooo tight. dressing or some silicone would be temporary. if you suspect its not the belts trry using a long screwdriver as a hearing aid and put it on the pulleys to identify if it is one of the pulleys or tensioners
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 07-19-2002, 09:07 AM   #6
David16
David16 is an unknown quantity at this point
my car has the same problem but it isnt the engine its my resignator(i think) well its something on the exhaust, I know you said yours was engine but if its not check that.
&lt;img src=http://www.steamymirror.com/dsc240sx/daves/8.jpg&gt;
David16 is offline   Reply With Quote
Old 07-22-2002, 01:22 AM   #7
YellwMonky
YellwMonky's Avatar
if i did want to tighten my alternator belt how would i go about doing it ? If I just got a new alternator belt do you think this will solve my problem?
