Old 10-22-2006, 11:13 PM   #1
bcrume
bcrume is a well-known jackass
rear brake pad replacement problem
I have an s13, putting on endless pads, brembo rotors and shims from kragen. I can't fit the the pads and rotor between the caliper, the piston is all the way back. Can I take the shims completely off? Is there some trick to it?
bcrume is offline   Reply With Quote
Old 10-23-2006, 12:36 AM   #2
BoNyG515
BoNyG515's Avatar
BoNyG515 is an unknown quantity at this point
Send a message via AIM to BoNyG515
theres sometimes some "dimples" on the back of the pad itself. you are suppose to reset the caliper piston all the way back and straight so that these dimples can line up to the "X" on the piston. I didnt do this once and I forced the pad on there, last time I checked the pads wore in a taper fashion...gl hope this helps
"Sugar we're going down swinging..."
BoNyG515 is offline   Reply With Quote
Old 10-23-2006, 04:38 PM   #3
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
This is correct. Just twist the piston to line up with the tabon the back of the pad and it will fit right over.
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 10-23-2006, 07:13 PM   #4
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
there is a box tool that you put onto a socket wrench that makes the job much easier
Slip Gypsies Blog
not sure if you realize this
Old 10-23-2006, 07:20 PM   #5
SlowCoupe
SlowCoupe's Avatar
SlowCoupe is an unknown quantity at this point
Send a message via AIM to SlowCoupe
you can find it at most local autoparts store. i got mine from napa b/c it down the street from me. its a cube with different pattern/size "nubs" that "grab" on the the piston of the caliper so you can twist it back in and to align the pads if they have the "nubs" on the back of them.
SlowCoupe is offline   Reply With Quote
Old 10-23-2006, 07:38 PM   #6
g6civcx
g6civcx's Avatar
Please remember to search next time before asking simple questions.
http://www.zilvia.net/f/showthread.php?t=93089
Old 10-23-2006, 09:15 PM   #7
BoNyG515
BoNyG515's Avatar
yeah I forgot to mention that you should use this box tool, "rear caliper piston reset tool" I think dats what its called haha or if you are careful enough, you can use some needle nose pliers...
Old 10-23-2006, 09:52 PM   #8
bcrume
I did search, do I have to say that in every post to not hear nagging? The piston was all the way back. I just took the shims off. I still had to hit it softly with a rubber mallet to get it on.
Old 10-24-2006, 05:49 AM   #9
g6civcx
g6civcx's Avatar
Yes. You should post the link to your search results as well.
Old 10-24-2006, 10:06 PM   #10
bcrume
g6civicx you are an asshole.
Old 10-24-2006, 10:11 PM   #11
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
He's right, and brake pads are a simple job bro.
Old 10-24-2006, 10:19 PM   #12
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
I used a needle nose. it's much simpler and much faster than the 'tool' but unfortunately sometimes the caliper is a little seized so using needle nose pliers in that scenario is pretty much useless.
shayrgob240 is offline   Reply With Quote
Old 10-25-2006, 12:30 PM   #13
bcrume
I posted about a specific problem, not a general question on how to replace brake pads. In my first post I said the piston was all the way back, the tool to turn the piston back is not what I asked about. There was only one post from someone actually trying to help. I guess this forum is just getting really bad.
Old 10-25-2006, 12:35 PM   #14
shayrgob240
we're saying push the piston back all the way b/c if u got the right pads then they should fit. If they don't fit, then you don't have the right pads.
Old 10-25-2006, 12:59 PM   #15
OBEEWON
OBEEWON's Avatar
The simple jobs always give the most trouble.
