Old 10-26-2006, 02:03 PM   #1
partymonster 975
partymonster 975 is a well-known jackass
What to change/replace during an RB swap?
Hey, I am planning on ordering an RB25 and I want to know if these are some good things to replace and change while doing the swap. Is there anything not listed I should replace?
I have comments next to the parts.
Thanks
Power Enterprise Timing Belt
Nismo Thermostat
Greddy Multi-Metal Headgasket 1.0 (maybe, what do you think?)
OEM Nissan RB25DET Oil Pan (I hear this is good to replace)
OEM Water Pump (not N1)
OEM Oil Pump
partymonster 975 is offline   Reply With Quote
Old 10-26-2006, 02:15 PM   #2
partymonster 975
BTW: I also want to get an Earl's oil filter relocator like this. Anyone know if these are any good?
Old 10-26-2006, 05:09 PM   #3
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
replace the rear main seal. you dont want to have to change that after the motors in the car. basically change anything that would be a total pita to change once the motor and tranny are already in the car. with in reason of course. as for the oil filter relocation kit. an oil filter relocation kit is a oil filter relocation kit is a oil filter relocation kit....kinda hard to mess up.
ladiesman8527 is offline   Reply With Quote
Old 10-26-2006, 05:45 PM   #4
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
^just dont get a fram filter.....
DJPimpFlex is offline   Reply With Quote
Old 10-26-2006, 06:11 PM   #5
partymonster 975
yea, I'm gonna use oem or K&N for the oil filter.
So is whats on the list good enough? I mean unless the parts on the motor are OK I wont buy them all but for what it is how is that, anything else that should be changed?
Old 10-26-2006, 06:59 PM   #6
DJPimpFlex
DJPimpFlex's Avatar
valve cover gasket, and the spark plug well gaskets, spark plugs, front and rear main seals, clutch would be a good idea, but not nessicary, basically every gasket, take the oil pan off and check te pump and pound out the pan if nessicary, radiator hoses, and probably more I just cant think of them right now.
Old 10-26-2006, 08:25 PM   #7
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
whats wrong with fram?
that shits done me just fine
Drift Indy
Edgar is offline   Reply With Quote
Old 10-26-2006, 08:34 PM   #8
partymonster 975
do you guys know what tests I should do, boost leak, compression, oil leaks, others?
Old 10-26-2006, 08:48 PM   #9
DJPimpFlex
DJPimpFlex's Avatar
leak down.......
oh and this is why not to buy fram...
http://minimopar.knizefamily.net/oilfilterstudy.html
http://www.zilvia.net/f/showthread.p...ram+oil+filter
