Old 11-13-2006, 07:07 PM   #1
Flat-Black
Flat-Black is an unknown quantity at this point
Ls1 240sx Complete
finished up my ls1 swap a while ago .. just whanted to post up some pics of the completed swap ..
info
2002 ls1 motor all stock tuning
t56- six speed trans
ls7 clutch
ported oil pump
koyo ka24de aluminum radiator with nissan altima dual fans
custom long tubes clears steering and frame rails .
3" 2 into 1 exhaust ( for the street) dyno max muffler .. nice and quiet except when wot
alum drive shaft ( drive shaft shop)
custom mounts and x member
spear tech harness
18x 9.5 wheels on all 4
full drift suspension [IMG]]
300zx brakes on all 4
awsome swap .. drove the car crazy fast . cant wait to drift it ..
heres some pics and a video
DYNO CHART ..
had a ka24de with carburetors in befor .. just didnt make enough power .
hood scoop is comming off .. was there for clearance on my previous carb set up
more vids soon and a dyno .
motor started
http://www.hostdub.com/albums/paco/240sx_004.avi
rev
http://www.hostdub.com/albums/paco/240sx_005.avi
open header with dynomax bullet mufflers at idel
http://www.hostdub.com/albums/paco/240sx_dyno_016.avi
on the dynos
http://www.hostdub.com/albums/paco/240sx_dyno_019.avi
http://www.hostdub.com/albums/paco/240sx_dyno_020.avi
just whent to the scales to get a weight of the car ..
2616 + 165 with me in it . this is with a 1/8 below 1/2 tank .. and i can still save a little by removing all the sound dedening .
a friend has a simaler car with a sr20de non turbo and he was at 2500
both our cars are gutted and pritty much the same except motor
Flat-Black is offline   Reply With Quote
Old 11-13-2006, 07:12 PM   #2
MURPHY
MURPHY's Avatar
MURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfection
Send a message via AIM to MURPHY
does your rad/fan combo work good?
"spear tech harness " ??
how much was driveshaft shop? and what all did you have to send em?
MURPHY is offline   Reply With Quote
Old 11-13-2006, 07:49 PM   #3
Flat-Black
the engine has yet to see any temp above 180
www.speartech.com . you send them your stock ls1 harness . your get a stanadlone harness thats 4 to 6 wires to install .
i sent dirve shaft shop nothing .. called em up . told them the lenght i needed and they made it . 450+shipping
Old 11-13-2006, 08:02 PM   #4
MURPHY
MURPHY's Avatar
so its the same price threw them for standalone as it would be for a normal wiring job threw HSC? haha sweet
and HSC's driveshafts are cheaper.
we need engine pics!
does the standalone when you send them your harness include engine light, fuel pump relay and diagnostic port?
Old 11-13-2006, 08:14 PM   #5
WhiteGLX
WhiteGLX's Avatar
WhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to all
Send a message via AIM to WhiteGLX Send a message via Yahoo to WhiteGLX
post some install pics.....im sure alot of people would like to know:
*which headers are your using?
*how did you do the mounts?
*does factory tack and speedo work accuratly?
*what HP did you make on teh dyno with a completely stock LS1?
*Which LS1 are you using? (what L or ci)
pics of anything would be great, this is a new upand comming popular swap, so all info would be great to have.
***NASA HPDE Instructor***
WhiteGLX is offline   Reply With Quote
Old 11-13-2006, 08:20 PM   #6
0100
0100's Avatar
0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute
Badass!!!!!!!!
Nice job.
TougeHero.com l SilviaV8forums.com
0100 is offline   Reply With Quote
Old 11-13-2006, 08:44 PM   #7
Irukandji
hey paco, its ben from altamont. good to see your car is finally donnneeee.
Old 11-13-2006, 09:08 PM   #8
HKSdrift3r
HKSdrift3r's Avatar
HKSdrift3r has a spectacular aura aboutHKSdrift3r has a spectacular aura aboutHKSdrift3r has a spectacular aura aboutHKSdrift3r has a spectacular aura aboutHKSdrift3r has a spectacular aura aboutHKSdrift3r has a spectacular aura about
that sounds insane!! can not wait to see more vids and pics. dont want to know how much that all cost you because i def cannot afford that.
btw wat size tires you running and suspension?? awesome car!!!!!!
HKSdrift3r is offline   Reply With Quote
Old 11-13-2006, 09:20 PM   #9
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Awesome...What kind of muffler/exhaust system are you running??Sound nice. Nice rims too by the way, get some more pics and specs. up.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 11-13-2006, 10:19 PM   #10
MURPHY
MURPHY's Avatar
wait on the ka koyo what upper/rad hose you using?
whats a ported oil pump help? and i take it a ls7 clutch is an upgrade, right?
any problems at all with your standalone? was it just pretty much plug and play one you got the new harness? and does everything work right?
Old 11-14-2006, 12:02 AM   #11
cmcdougle
cmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to behold
Send a message via MSN to cmcdougle
that sounds cool. Post some pics of the engine, and of your motor mounts. I would like to see what they look like.
Fun swap. How long did it take?
cmcdougle is offline   Reply With Quote
Old 11-14-2006, 12:41 AM   #12
Flat-Black
i am running headers that i made to fit . pain in the a$$ but well worth it .
custom crossmember to clear oil pan and sit the motor just right
motors a 2002 ls1 5.7
no dyno yet .. possibly tomorrow
speedo not hooked up yet . nor tack
speartech harness cost 450 . well worth in imo . comes with everything you need to make it a sweet simple install . dignostic port as well
ls7 clutch is an upgrade over stock ls1 clutch flywheel set up.
oil pump does help . higher pressure for sustaning high revs
cost of the swap was rediculous .. had to spend lost of monye on trial and error parts , mounts , corssmembers , fans , ext ext . but well worth it
wheels and tires are sport max 962? 18x9.5 all the way around . 245-35-18 azenis front . 265-35-18 ziex in the back .
exhaust is dual dyno max bullet mufflers merged into 1 then out a nother dynomax muffler . makes it nice and drivable on the street . will post up video of staight bullet mufflers . sounds insane.
Old 11-14-2006, 01:25 AM   #13
quach
quach is an unknown quantity at this point
holy shit paco you finished this shit hella fast! werent you talking about doing this just a couple months ago? this is marcus from altamont by the way. you've got some serious skills man, that shit is sick.
quach is offline   Reply With Quote
Old 11-14-2006, 02:54 AM   #14
mrmephistopheles
mrmephistopheles's Avatar
Ah, my car is done! I'll take delivery of it when we get back to the states.
Take care of it for me!
Originally Posted by PHLIP
Old 11-14-2006, 03:51 AM   #15
SLEEPERracer
SLEEPERracer is an unknown quantity at this point
damn thats dope! sounds really mean too!
SLEEPERracer is offline   Reply With Quote
Old 11-14-2006, 05:24 AM   #16
Wykydtron
Wykydtron's Avatar
Wykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really nice
How much of a budget are you working with for this swap? I'm curious because I have a friend that has a dad thats a v8 nut. My friend really wants my SR and I told him as long as he found me a decent LS1 we can negotiate some sort of deal. XD
@schassis.eddi
Wykydtron is offline   Reply With Quote
Old 11-14-2006, 05:48 AM   #17
Flat-Black
hahah thanks quach .. yea remember when i was sick of the ka ..lol ..
swap took me approx 2moth for start to were it is now . started sep 1sth and finished it late october . mainly weekends tho ..
budget can range on whant you can make your self .. i make everything b/c of how expensive it would be to go threw hinson.
but expect the entire ls1 swap to put you back 6-8k thats what i would calculate for a nice clean swap.
Old 11-14-2006, 06:54 AM   #18
g6civcx
g6civcx's Avatar
Nice job. Thanks for posting. Can you give us more detailed pix?
The crate motor alone is about $6k plus shipping if you want a new motor. The conversion parts from Hinson is pretty expensive if you can do the fab yourself. It looks like I'm going to have to go with Hinsonthough because I'm not good at fabbin'
Old 11-14-2006, 07:45 AM   #19
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
man thats one nice swap there bro
Slip Gypsies Blog
not sure if you realize this
Old 11-14-2006, 08:18 AM   #20
ms!3
got any pics of the old ka setup? ls1 is bad ass but theres something about na ka's that i like, ive never seen a carbed double cam.
ms!3 is offline   Reply With Quote
Old 11-14-2006, 08:29 AM   #21
Wykydtron
Wykydtron's Avatar
I hear ya! I wouldn't trust my welds now, especially not having practice for 2 years! It would take some time to relearn but I wouldn't trust the strength of the welds to the torque of a v8.
It definately would be nice to pick up a crate motor, but then again maybe someone could track down a used one.
@schassis.eddi
Old 11-14-2006, 11:55 AM   #22
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
cong. on the swap.. but a little off topic
i know I'm asking some a$$ backward question, but you are the first person that I've ever saw that has carbs. on a dual cam KA engine.
how did you do that? what intake manifold and carbs did you use? and how was the power delievery?
gunluvS14 is offline   Reply With Quote
Old 11-14-2006, 12:20 PM   #23
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
Originally Posted by MS!3
got any pics of the old ka setup? ls1 is bass ass but theres something about na ka's that i like, ive never seen a carbed double cam.
hah I'm with you the ls1 is cool, but I want more info on that ka setup. Are those weber's? dcoe 44's? if not what size are they? How much power did it make? cams and header?
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 11-14-2006, 01:37 PM   #24
twistex
twistex is an unknown quantity at this point
Send a message via AIM to twistex
sick!!!!!!!!!!!
twistex is offline   Reply With Quote
Old 11-14-2006, 01:43 PM   #25
RoyalFlush
RoyalFlush's Avatar
RoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura about
what are you doing with the KA you pulled
RoyalFlush is offline   Reply With Quote
Old 11-14-2006, 02:03 PM   #26
MURPHY
MURPHY's Avatar
Old 11-14-2006, 04:54 PM   #27
Flat-Black
ka is pulled and sold .. anyone who does a ka carbed in a 240sx will be disppointed .. keep it efi and do itbs ..
upper rad hose is somthing i got a autozone and made it fit .. just a plain
90 to 90 hose .. simple .
Old 11-14-2006, 06:40 PM   #28
ms!3
sooooooooooo.......got any pics of the ka. i could use more on my picture folder. lol i just like em even tho there slow with all the money you put into them.
Old 11-14-2006, 08:33 PM   #29
Flat-Black
dyno chart and dyno runs posted ... 324WHP AND 333TQ
300+TQ STARTING FROM 2.5K TO REDLINE .. SWEEETTTTTT
Old 11-14-2006, 08:44 PM   #30
MURPHY
MURPHY's Avatar
do you know the parts number for the radiator hoses you bought? its seems like alot better idea and cheaper since i have a Taurus fan already. thanks
i love hoe the ls1 looks no normal in there. any fitment issues at all? wow nice dyno too
