Ill try to explain and if anyone sees that more info needs to be added jus add some more.
Red-Top S13 SR20DET 180SX 91-93 and Silvia 91-93 Black-Top S13 SR20DET 180SX 94-98 Displacement: 1998cc (2.0 liter) Cam type: DOHC 16 valve, chain driven cam sprockets Bore and stroke: 86mm x 86mm Compression: 8.5 : 1 Horsepower: 205hp at 6000rpm Torque: 203 ft/lbs at 4000rpm Stock boost: 7 psi Throttle body bore: 60mm Turbo specs: Injector size: 370cc/min Compressor: T-25, 60 trim 56mm BCI-1 compressor. Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Center Section: Journal bearings The difference in those engines i believe the 91-93 used high port and also 94-98 used high port as well. but someone please correct me if i am wrong okie? Now hear are the specs for the S14 Blacktop. That came equipped wid the Variable vavle time system. The S14 used low port unlike the S13 used high port.. Black-Top S14 SR20DET Silvia 95-98 Horsepower: 220hp at 6000rpm Torque: 203 ft/lbs at 4800rpm Turbo specs: Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Center Section: Ball Bearing I took the specs from Heavy throttle, i hope this helped you in ur quest for a sr20det.. later |
yep, that is basically it. s14 have VTC variable intake cam timing, and a t28 ball-bearing turbo, while the s13 from '91-93 has the red valve cover, and the '94-98 180sx has a black valve cover, but they both have the same turbo and everything. s13 blacktop does not have VTC. So it is basically the exact same engine but with a different color valve cover.
Sorry, I forgot to mention that the s14 does not have a low-port head, only the s15 have the low port, s13 and s14 have the high port head.
And installing a t28 turbo would have a much quicker spool up time because they have a ball bearing center section, but the power potential is not all that different. |
![]() Join Date: May 2001
I was told that the redtop sr are better because the black top sr tend to blow easier. My friend in Oki told me that so he is giving me a redtop sr for my old dime.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sil80bill @ July 22 2002,11:36)</td></tr><tr><td id="QUOTE">Sorry, I forgot to mention that the s14 does not have a low-port head, only the s15 have the low port, s13 and s14 have the high port head.</td></tr></table><span id='postcolor'>
Wrong... S14 SR's have low port head. S13's have high port. None have been proven to work better or worse. |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (dstyle @ July 23 2002,03:36)</td></tr><tr><td id="QUOTE">I was told that the redtop sr are better because the black top sr tend to blow easier. My friend in Oki told me that so he is giving me a redtop sr for my old dime.</td></tr></table><span id='postcolor'>
Why?? They the same motor. Don't go spreading misinformation just because your friend said so. If you have proof to back that statement up then by all means let me hear it. If not then stop posting this crap. Not trying to be a ====> I just get sick of people posting information that they have no first hand knowledge of. |
