![]() Join Date: Oct 2006
![]() ok guys i need some help here!!! i have a 1990 240 with an sr in it, but no power steering. i have the dohc pressure line and the hard lines and the reservoir. but on the sr pump there are two wholes were either the pressure line or the return line goes, i dont know wich one goes where, and i dont have a return line some one please give me a diagram setup or some pics of your own sr power steering setups thanks
koukidrifter ![]() |
![]() Join Date: Mar 2004
SR Power Steering woes FTW!
The pressure line is connected to an elongated metal hose via a banjo bolt. That elongated hose, in turn, connects to the PS pump via another banjo bolt. The suction pipe (curved, metal piece) connects the PS pump to the PS resevoir via a rubber hose. Hopefully that made sense and helps. Good Luck! |
the hole on the top is where the high pressure hose connects with the large bolt with the two crush washers, and where the hole on the side is should have a curved metal tube attached to it by two bolts and that is the return line that should have a piece of hose attached to it with a hose clamp.
here's an idea: why don't YOU post pics so that we know what YOU are talking about and perhaps help you out.
also the FSMs are readily available if you search. |
