Old 07-21-2002, 02:08 PM   #1
YellwMonky
YellwMonky's Avatar
YellwMonky is an unknown quantity at this point
I just hit 128,000 miles and i'm thinking I might need a major tune up. I was thinking of replacing my cap and rotor but I'm not sure if I have to. What are some symptoms that will tell me that I need to change them?
s13 92 White 240sx SE Coupe
YellwMonky is offline   Reply With Quote
Old 07-21-2002, 04:17 PM   #2
Jdm_Silvia
Jdm_Silvia is an unknown quantity at this point
might as well do it. I just changed mine was easy and not expensive. something like 16 or 17 dollers <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
What are you Talking About Man???????
Jdm_Silvia is offline   Reply With Quote
Old 07-21-2002, 08:33 PM   #3
Yosho
Yosho is an unknown quantity at this point
When were they last replaced? &nbsp;As JDM_Siliva said... it's cheap, so why not go ahead and do it.
- Yosho
'93 Nissan 2000 GSR
'96 200SX SE-R
'00 Civic Si (For Sale)
Yosho is offline   Reply With Quote
Old 07-21-2002, 09:41 PM   #4
Natty
Natty is an unknown quantity at this point
I haven't looked at mine too much, but how hard is the install? Do you just unhook the battery, pull the distributor wires, pull the old stuff off and then replace?
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 07-22-2002, 08:39 AM   #5
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Well if there is no evidence of them ever being replaced, you may be in luck actually. &nbsp;You may feel the difference in performance and be one of the statistics where new wires really do make 10hp. &nbsp;Maybe not, but you're still WAY overdue for the change.
As said above, it's fairly cheap and very easy. &nbsp;A wire, cap and rotor swap will take 30 minutes, but don't rush it. &nbsp;
New wires are the most expensive at $50, the cap and rotor are like $7 each at courtesy nissan.
Two things to watch out for are that the rotor goes on two ways, the right way and the wrong way, so just watch and make sure you put it back on facing the same direction it came off and you'll be fine (it would actually be pretty hard to screw up, unless you didn't even look at the direction it was before you took it off).
The other thing to note is that the cap is not in order. &nbsp;As you go around the order is 1,2,4,3. &nbsp;Just make sure you don't assume it to be 1,2,3,4 and wire them all in sequence (it's all marked on the cap as well).
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 07-22-2002, 08:54 AM   #6
four
four's Avatar
four is an unknown quantity at this point
Send a message via AIM to four
what are signs that you need to replace your distributor cap and rotor. &nbsp;I bought my car used, and I dont know if it has been changed. &nbsp;I have just about 90000 miles
four is offline   Reply With Quote
