Old 12-29-2006, 05:10 AM   #1
deevietboi
deevietboi's Avatar
deevietboi has made poor choicesdeevietboi has made poor choicesdeevietboi has made poor choicesdeevietboi has made poor choicesdeevietboi has made poor choicesdeevietboi has made poor choices
nitrous on a sohc?
ok first off i have a 1990 sohc 240sx fastback completely stock just tein springs and KYB suspension.
Shes to slow and i want to boost her up real quick without blowing the motor and i was thinking about putting a nitrous system in her for now and put the kit into a new motor later. i have 800bucks for a nitrous system and i wanted to no what brand would be good to go with.
Whats the difference between wet and dry systems?
where would place the switch? when should i press and what rpm do i use the nos?
could my stock engine take nitrous without any major mods?
50-75 shot of nitrous
she will be replaced by a twin cam ka24de soon when my shop finds me a motor
deevietboi is offline   Reply With Quote
Old 12-29-2006, 07:21 AM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
wet systems inject nitrous in with the fuel (more expensive, more risky)
dry systems inject nitrous in with the air (cheaper, less power less risk)
50-75 on a Ka should be fine. make sure you have less than 200,000miles on it.
you'll have an arming switch placed somewhere in the cabin and the actual injection then occurs at wide open throttle.
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 12-29-2006, 01:17 PM   #3
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
i work at an engine shop, and i just rebuilt a ka24de that i picked up when a buddy did his sr20 swap. when it came out it was a good running engine with only 70k miles. shoot me a pm if your interested, i just want to make it disappear and will take any reasonable offer, plus i can build it any way you want, IE forged components and the such
lazierhobo is offline   Reply With Quote
Old 12-29-2006, 02:13 PM   #4
!Zar!
!Zar!'s Avatar
You should have no problem running nitrous.
Just make sure your ignition tuning is correct.
Before you do anything, check your compression.
Old 12-29-2006, 03:01 PM   #5
deevietboi
deevietboi's Avatar
sounds like a plan! hmm my engine has about 185k miles on it... will that do??
what about tuning? will i need to mess with the A/F ratio in any ways?
whats a good brand to go with?
how much am i looking to pay for a dry system?
Old 12-29-2006, 05:14 PM   #6
deevietboi
deevietboi's Avatar
planning on a dry system but how long do u think my engine with 182k miles on her will last with it installed and used 2-4 times a week mostlikely night time use
should i go with a 2 1/2 inch free flow exhaust with no cat?
exhaust either RSR EXMAG or Blitzs nur spec R 3inch exhaust
Old 12-29-2006, 11:32 PM   #7
RHDintegXSI
RHDintegXSI is making a name for him/her selfRHDintegXSI is making a name for him/her self
dry systems are the basic of the basic systems..they work frelatively fine as long as you dont go anything over ~50 shot
for peice of mind i would go with a wet kit. a lot more reliable since you have the extra fuel to help avoid lean conditions.
with that said tuning is key. make sure you have plenty of fuel, a little rich is better than a little lean and retard your timing a couple degrees
96 Mitsubishi Eclipse sold
92 RHD converted Integra current
02 Honda Accord V6 current
89 Nissan 240sx Coupe current
YES my other cars a HONDA
RHDintegXSI is offline   Reply With Quote
