Old 01-06-2007, 01:03 PM   #1
shigitySxSe
shigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to allshigitySxSe is a name known to all
Send a message via AIM to shigitySxSe
s13 windshield wipers
So this may sound like a dumb question.....but i cant figure out why the hell my wipers make the high pitched noise that they do. I just recently had a new windshield installed and the wipers i just put on last week. EVERY time it seems i go to use them, dry/rain/snow whatever they go "Wrrrreeeee Wrrreeeeee" each time they go up and down. I know that i put brand new wipers on correctly and my windshields clean, but why the hell is it making this noise??!!
shigitySxSe is offline   Reply With Quote
Old 01-06-2007, 02:23 PM   #2
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Its the sound of rubber dragging across a glossy dry surface. Try putting some Rain-X on (rub in on with a cloth) and see if it helps make the glass slicker and less noisy.
400x200
mbmbmb23 is offline   Reply With Quote
Old 01-06-2007, 02:39 PM   #3
wheresthaboost?
wheresthaboost?'s Avatar
wheresthaboost? is an unknown quantity at this point
slap some butter on that bad boy...
RB25DET S13
wheresthaboost? is offline   Reply With Quote
Old 01-06-2007, 03:28 PM   #4
projectRDM
projectRDM's Avatar
Clean the blades thoroughly with isopropyl alcohol.
Old 01-06-2007, 05:27 PM   #5
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
Your wipers might be sitting at an angle. I've heard of people slightly bending them so they won't squeak.
& Fill your washer fluid reservoir with deionized / distilled water. Cheap & no water spots when it dries!
Anto is offline   Reply With Quote
Old 01-07-2007, 12:42 AM   #6
!Zar!
!Zar!'s Avatar
Bingo.
Follow that and you're golden.
Old 01-07-2007, 09:08 AM   #7
shigitySxSe
alright thanks alot guys...im gonna go try pretty much everything youve said
Old 01-07-2007, 05:12 PM   #8
DonDeago
DonDeago is an unknown quantity at this point
I took mine off and now use rainex..heavily. Looks cleaner that way, but I'd also suggest just cleaning them very well.
DonDeago is offline   Reply With Quote
Old 01-07-2007, 06:34 PM   #9
EndLeSS8
EndLeSS8's Avatar
EndLeSS8 will become famous soon enoughEndLeSS8 will become famous soon enoughEndLeSS8 will become famous soon enough
I use Valeo. Tirerack had them on sale 2 for 1 a couple months back.
Very good set.
268generation.com
-United for His Renown-
EndLeSS8 is offline   Reply With Quote
Old 01-07-2007, 06:40 PM   #10
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
how old are the wipers if its pretty old then get new ones thats probably why as they get older they would wear down and have taht squeaky noise. and as what it is said above clean them with isopropyl alcohol
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 01-08-2007, 12:28 AM   #11
shigitySxSe
theyre are brand new rainex wipers....but whats interesting is that the sound went away when i pulled the wipers off from the window. Like, you know holding them out, and then using my wipers....and the sound was still there. So the sound isnt from the wiper being on the windshield...its coming from somewhere at the base of the wiper-arm. All i really saw was a bolt down near the base of it but tightening that wasnt making a difference. Any ideas?
