Old 07-29-2002, 07:58 AM   #4
AKADriver
AKADriver's Avatar
This really should be done by a competent transmission/differential shop.  The differential needs to be preloaded with shims both to even out the clearances and make sure the gears contact each other the right way.  It's not easy to DIY.
$225 is really pushing it for just the chunk, because of the labor costs involved, plus you'll still need the LSD output shafts at $150 apiece.
