Old 01-23-2007, 07:43 PM   #1
OBEEWON
OBEEWON's Avatar
Wipers
My affliction continues. I can be driving and hit a bump, make a turn or just sneeze and my wipers come on and wont turn off. At first I could just turn the ignition off and they would stop, but now they go off when they feel like it and come on when they want. The intermittent setting on my wipers does not work but the other two speeds do. I searched and didnt find an answer even though quite a few people have this problem. Anyone know what to do?
Old 01-23-2007, 10:13 PM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
hA same shit as me, theres gotta be something that is causing this, I wish someone knew.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 01-23-2007, 10:18 PM   #3
projectRDM
projectRDM's Avatar
1) Replace wiper switch.
2) Replace wiper amplifier.
3) Replace wiper motor.
Has to be one of those three parts.
Old 01-23-2007, 10:21 PM   #4
mjjstang
Hmm could you please explain why it could be the motor?
Old 01-23-2007, 10:25 PM   #5
projectRDM
projectRDM's Avatar
Doubtful that it is, but it's a process of elimination. The switch or the amp are usually the culprit 99% of the time, but to verify for certain you can swap the motor out as a last ditch effort if the other parts don't fix it. After that, it's a harness problem. For S13s you'll be working in the underhood harness, for S14s it's all located in the dash harness. I have replaced one motor in my time of dealing with these cars, so anything is possible.
Old 01-24-2007, 08:10 AM   #6
OBEEWON
OBEEWON's Avatar
Man in the dash!! How hard is it to get to the motor in a S14. I guess I should start in my stearing column and check the wiring first then right?
Old 01-24-2007, 08:27 AM   #7
YucA
YucA's Avatar
YucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of light
if your cars are lowered and you havent relocated the harnesses inside the fender well, you could have chewed up the wires under there causing this randomness. I've seen it happen too many times.
To check just remove the drivers side wheel and lookup into the well, if you see bare wire...thats it...
YucA is offline   Reply With Quote
Old 01-24-2007, 09:27 AM   #8
OBEEWON
OBEEWON's Avatar
Thats the funny thing. Ive chewed through those wires a few times but in those instances never had an issue with my wipers. I relocated it a long long time ago with no issues since. But all of a sudden they start to act up.
Old 01-24-2007, 09:38 AM   #9
projectRDM
projectRDM's Avatar
Lowered cars won't have that issue on S14s, none of the wiper wiring runs out under the hood through the fenderwells. If it was an ignition related problem with the wiring you'd have other things going out intermittently.
The wiper motor is 4 bolts, very easy, but definitely check the switch and amp first, those are more prone to having issues.
Old 01-24-2007, 03:55 PM   #10
OBEEWON
OBEEWON's Avatar
Thanks alot dude. I tried to give you more rep points but they say I have to spread it around first.
Old 01-24-2007, 05:54 PM   #11
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Your rep is worthless. Haha. Anyways, having wiper problems suck, especially when it's raining, and all you can do is put a crap load of rain x, and drive really fast so you can see.
Old 01-25-2007, 10:49 AM   #12
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
rainex FTW!
dmn msgleht
pbcstylez is offline   Reply With Quote
Old 04-05-2007, 08:54 AM   #13
OBEEWON
OBEEWON's Avatar
Just an update for anyone with this issue. It was the brown relay hidden inside the fender that was bad (relay or amplifier not sure what its called). Figured it out after I swapped the switch and the motor with my 96. Hope that helps someone.
