Old 01-27-2007, 12:37 PM   #1
Jimmy Up
Zilvia.net GB Vendor
Jimmy Up's Avatar
Trader Rating: (52)
Feedback Score: 52 reviews
clutch or tranny???
i just bought a 92 hatch 3 days ago and last night when i would roll to a red light that turned green and tried to put it into second, it was kind of hard. this morning i went to drive the car and the car started clutch down, but would not go into gear. i shut the car off and put it into first and started it, it started idling pretty rough. i took off and all the gears were really rough to go into and one time i couldnt even go into 4th, it buzzed. this is the first manual car i have owned and ive only owned 240s for like the passed few months so i dont know much about them. any help is appreciated. thanks mike
WWW.JIMMYUP.COM
Old 01-27-2007, 12:40 PM   #2
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
sounds like a clutch problem to me. its not disengaging all the way or something
lexus baby
5t341tH is offline   Reply With Quote
Old 01-27-2007, 12:49 PM   #3
chlatboy
chlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enough
bleed the clutch system.
If you dont know
SEARCH!!!
chlatboy is offline   Reply With Quote
Old 01-27-2007, 01:00 PM   #4
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
i know it might sound dumb but any tips on how, im pretty mechanically inclined, i just dont know these cars. thanks
WWW.JIMMYUP.COM
Old 01-27-2007, 03:11 PM   #5
5t341tH
5t341tH's Avatar
jack the car up and put on stands. go under ur car and look for the clutch slave. theres a screw in there, use a bleeder wrench to open it up while someone pumps/holds on the clutch pedal
lexus baby
Old 01-27-2007, 03:15 PM   #6
chlatboy
slave has a rubber line that goes to the hardline. Its connected to the tranny by two bolts.
If you dont know
SEARCH!!!
Old 01-27-2007, 03:27 PM   #7
s15lover1987
s15lover1987 is an unknown quantity at this point
Send a message via AIM to s15lover1987 Send a message via Yahoo to s15lover1987
if its not the clutch it self it may be your pilot/throw out bearing. or an other thing it may be is your flywheel is slipping and may need to be replaced.
s15lover1987 is offline   Reply With Quote
Old 01-27-2007, 03:30 PM   #8
s15lover1987
that buzzing is your pilot/ or throw out bearing. it does that because its dried up and has no kind of lube on it. so check both your pilot bearing and your throw out bearing, and your flywheel. it sounds like your clutch isnt engaging completely
Old 01-27-2007, 03:31 PM   #9
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
right on thanks, im gonna hop on this tomorrow morning- hopefully i wont need a new clutch. appreciate it guys
WWW.JIMMYUP.COM
Old 01-27-2007, 03:43 PM   #10
s15lover1987
another thing you can try is when you have it apart.. spray all your bearings with WD40 or some Graffite. and that may stop it for a while . also what kind of gear oil do you have in there
Old 01-27-2007, 05:16 PM   #11
s13speeddrft
s13speeddrft's Avatar
s13speeddrft is a jewel in the roughs13speeddrft is a jewel in the roughs13speeddrft is a jewel in the roughs13speeddrft is a jewel in the roughs13speeddrft is a jewel in the roughs13speeddrft is a jewel in the roughs13speeddrft is a jewel in the roughs13speeddrft is a jewel in the rough
Send a message via AIM to s13speeddrft
do not use wd40 it attracts dirt
http://s165.photobucket.com/albums/u63/ajhartma/
1990 240sx hatch....currently monster truck status, with sunken battleships.
*Junkyard Scavenger*
s13speeddrft is offline   Reply With Quote
Old 01-27-2007, 05:50 PM   #12
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
have no idea what kind of gear oil, i just bought the car 3 days ago so im kinda pissed that this is going on, but lifes a btch
WWW.JIMMYUP.COM
Old 01-28-2007, 11:51 AM   #13
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
if bleeding the clutch doesnt work, and you decide to check the TO/pilot bearings, you might as well replace those and the clutch while your there, its not that expensive to get the parts.
smurfgcr is offline   Reply With Quote
Old 01-28-2007, 12:17 PM   #14
chlatboy
about 150 for a clutch. Do it yourself and use a FSM for torque specs
If you dont know
SEARCH!!!
Old 01-28-2007, 01:15 PM   #15
Arruda
Arruda is on the path to ruinArruda is on the path to ruin
make the mofo BLEED
Arruda is offline   Reply With Quote
Old 01-28-2007, 01:36 PM   #16
A Spec Products
A Spec Products's Avatar
Not your tranny
Similar thing happened to me
Cept I couldn't put into ANY gear when car was on
Opened it up and clutch disk springs made a run for the border
It's probably clutch disk
Bleed it first, if that don't work then
Just replace clutch and call it a day
Life isn't over
You live in Covina/Socal too, so getting an OEM replacement is dirt cheap, labor is dirt cheap too
A SPEC PRODUCTS CORP
Old 01-28-2007, 01:44 PM   #17
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
for sure, im gonna try bleeding it as soon as my girlfriend can get over to pump the clutch for me. thanks for all the help
WWW.JIMMYUP.COM
Old 01-28-2007, 02:08 PM   #18
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
got a problem. im bleeding the clutch off of the slave and i got it all out, then i filled it back up and pumped the clutch with the bleeder closed and noting happened, so i cracked the bleeder a little bit and kept pumping, now the fluid is going straight through all the lines and out the bleeder but i still have no hydraulic pressure in the clutch it just sticks to the floor.
WWW.JIMMYUP.COM
Old 01-28-2007, 05:55 PM   #19
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Hello if you opened the bleeder & then kept pumping you may have introduced air back into the system???? Only pump pedal with bleeder closed. Anyhow sounds like it time for a clutch job.
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 01-28-2007, 07:11 PM   #20
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
well yea, lol i figured that out after like 3 min of straight pissing away brake fluid. but yea i just cannot get any pressure back in the clutch petal itself
WWW.JIMMYUP.COM
Old 01-28-2007, 08:22 PM   #21
smurfgcr
its going to take a while to get back pressure in the pedal if there is that much air in the line. pump the pedal and hold it down, then open the valve and close it again. repeat. repeat. repeat. pressure will build up slowly. if you do end up having to do clutch, DO NOT FORGET TO REPLACE PILOT BEARING.
Old 01-28-2007, 08:49 PM   #22
rsxrcr87
rsxrcr87's Avatar
rsxrcr87 is on a distinguished road
Send a message via AIM to rsxrcr87
your clutch master cylinder could be going out. Mine was on its way out and it would do that. But I just Changed it today so its good.
rsxrcr87 is offline   Reply With Quote
Old 01-28-2007, 09:04 PM   #23
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
thats what im thinking because the pedal will sink just a little bit when its bled but will not build up its just like starting fresh every time, how much do those run?
WWW.JIMMYUP.COM
Old 01-28-2007, 10:09 PM   #24
smurfgcr
i think i got my master for like 15 or 20. quite cheap.
Old 01-29-2007, 07:16 AM   #25
Dream240
Dream240's Avatar
Okay wait....you completely removed all the fluid in the M/C and then proceeded to refill and wondered why you had no pedal return? You just completely filled the system with air!!! I'm sure this car is stock which means you still have the clutch dampener installed remove it with this:
http://www.nostreetracing.org/forums/article.php?a=11
Missing pics but you should be able to follow the instructions.
Just get rid of the box and re-bleed. Really it's the same as doing a brake bleed:
1. pumpx3....hold pedal
2. Release bleeder screw for 3 seconds...retighten
3. repeat
4. re-fill resevior as needed....DO NOT aloow the level to go below the resevior!!
