Old 01-30-2007, 04:07 AM   #31
FRpilot
FRpilot's Avatar
good thread. sticky!
FRpilot is offline   Reply With Quote
Old 01-30-2007, 05:58 AM   #32
S14DB
AFC #1
S14DB's Avatar
Originally Posted by AkinaSpeed
Alright here is the situation, I wanted to try the S13 exhaust cam on the intake side of my S14 KA. I used this pic as a guide from NICO.
According to this there is, 9 links between the marks on the cam sprokets.
1) Tried it the way its on the pic and my car wouldn't start.
2) Move the exhaust cam sproket over one link, so now its down to 8 links. The car started but had advance my timing up to 30 deg to get it to idle smoothly.
My question is where did I go wrong??? I TDC the motor with the cams lobes pointing out everytime. Should I scrap the this mod or should I attemp it one more time??
TDC with the #1 lobes pointing straight out is correct. It sounds like you messed up your distributor alignment.
Old 01-30-2007, 06:05 AM   #33
AkinaSpeed
AkinaSpeed's Avatar
AkinaSpeed is an unknown quantity at this point
sorry double post
AkinaSpeed is offline   Reply With Quote
Old 01-30-2007, 06:09 AM   #34
AkinaSpeed
AkinaSpeed's Avatar
I was thinking something like that but when I was doing this I never pulled out my distributor. I was able to to take off the cams without removing the front upper cover??? Thats whats strikes my weird ??
Thanks for the input
Old 01-30-2007, 06:46 AM   #35
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
by 248/232 being where its at, you mean 248 on the intake side correct?
sorry for the dumb question
either way, sounds like i need a 248!
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 01-30-2007, 07:14 AM   #36
ls180sx
ls180sx will become famous soon enoughls180sx will become famous soon enoughls180sx will become famous soon enoughls180sx will become famous soon enough
And everyone says theres no good info on nico
ls180sx is offline   Reply With Quote
Old 01-30-2007, 12:32 PM   #37
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
thats why i brought it over to zilvia, because we are the pwnage
Slip Gypsies Blog
not sure if you realize this
Old 01-30-2007, 01:32 PM   #38
S14DB
AFC #1
S14DB's Avatar
how did you keep the bottom link aligned? release the tensioner? where is the other alignment marker?
Old 01-30-2007, 03:20 PM   #39
AkinaSpeed
AkinaSpeed's Avatar
Dude thanks for the help I finally figure it out. You were right initially, the timing was off and plus the first time me and my friend aznpoopy had it running was corret. All I had to do it was reset the dizzy back to TDC and it was done
Old 01-30-2007, 03:23 PM   #40
nissandr1ft
nissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura about
Send a message via AIM to nissandr1ft
What are your impressions so far of the powerband?
www.carolinanissans.com
nissandr1ft is offline   Reply With Quote
Old 01-30-2007, 04:03 PM   #41
aznpoopy
aznpoopy's Avatar
congratulations arthur!
Old 02-17-2007, 11:26 AM   #42
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
Arthur, Impressions? *a
'90RPS13 is offline   Reply With Quote
Old 02-17-2007, 12:34 PM   #43
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Do it the way it is in the picture, mine works perfectly, I think you just need to adjust your distributor timing. Don't move the cams over, or you might end up with bent valves.
Edit
Nevermind.
Old 02-17-2007, 02:15 PM   #44
Iceman00
Iceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymore
Seen this a while ago. Good info.
* > Drifting
JWT powered Altima
Iceman00 is offline   Reply With Quote
Old 02-17-2007, 02:55 PM   #45
ms!3
good info, i think i might try the 248/232 setup, im running 248/248 and love the sound but i lost a good amount of low end and cant really make up for it in the top end cuz im close to redline when it starts to pull. hows the sound with 248/232? lol i might just stay with the dual 248 becuase im not sure how much of a difference i'll feel with swaping in a 232, and you gotta love how it growls with dual 248s, haha
ms!3 is offline   Reply With Quote
Old 03-13-2007, 09:29 PM   #46
nissandr1ft
Well I swapped in a cam to the intake side, but I didnt notice much difference over the 232/232 cam setup and Im wondering if I have the correct cam in there. The cams I grabbed came from a 91 hatch, and I used the green cam since they were out of the car. Ive heard that the colors were reversed from S13 to S14. Looking at the JWT website his look to be in the same order as mine. Pictures of my cams before I pulled the intake side...
Im thinking either with the change of overlap my timing was retarded a bit, or I've got a 240 cam on my intake side isnstead of the 248 which I planned on using.
Old 03-13-2007, 10:07 PM   #47
punxva
punxva's Avatar
Trader Rating: (31)
hmm, i havent actually done any of the swaps myself, but im sure someone on here can verify this for you bro
Slip Gypsies Blog
Old 03-14-2007, 12:00 AM   #48
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
form what i have read, and reviewed in this thread, S14 with the swap should have two oranges, not an orange and a green. feel free to correct if wrong, but that is the findings, so if your swapped and have a orange and a green still, you didn't sue the 248 nissandr1ft.
and due to the Rb25 showing up soon, i will not be doing this cam swap anymore.
Tenchuu is offline   Reply With Quote
Old 03-14-2007, 11:57 AM   #49
nissandr1ft
The exhaust cam originally in my s14 motor was green, but yeah now I have 2 green cams. I dont know if this explains anything, but you do here more intake at WOT and the exhaust seems a tad quieter. The car doesnt "feel" as fast as it originally did, but my butt dyno isn't always right.
Old 07-04-2007, 04:46 PM   #50
ms!3
anybody running dual 248s? how does yours idle? mine is alittle rough, sometimes sounds like its missing. prob off a tooth. lol.
Old 07-05-2007, 10:51 AM   #51
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
great thread. I did my cam swap like 3-4 years ago and just matched the colors lol! So I think I will go back and switch the in/exh. I hope I still have my stock cams so I can try out the 232 on the exh.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 04-14-2009, 07:42 PM   #52
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
I know this thread is old but vert relevant. On a 240/240 cam swap how many teeth do i set it back? I have one came lob pointing up and the other is in proper position.
WangonwWarrior is offline   Reply With Quote
Old 04-14-2009, 07:57 PM   #53
WangonwWarrior
I was wondering how many teeth i need to move the exhaust cam on the 240/240 cam swap. any help is appreciated
Old 04-14-2009, 08:28 PM   #54
TanaMU
TanaMU will become famous soon enoughTanaMU will become famous soon enoughTanaMU will become famous soon enoughTanaMU will become famous soon enough
Any, uh, dyno results to back up these claims? Or is this just one guy's opinion?
TanaMU is offline   Reply With Quote
Old 08-20-2009, 11:08 AM   #55
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
im runnin the 248 with intake mani with a plenum an i f'in luvin it bro..way broader power band them runnin them with stock intake mani plus i got tuned ecu from efi specialist and my redline is at 8.but they seem to be pretty bad ass with my current set up..
project-D180 is offline   Reply With Quote
Old 08-20-2009, 11:33 AM   #56
JesusFreakDrifter
JesusFreakDrifter's Avatar
JesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud of
non turbo...wow....wat is ur cam setup, just the 248intake
JesusFreakDrifter is offline   Reply With Quote
Old 08-20-2009, 06:18 PM   #57
project-D180
248 intake n exhaust
Old 08-20-2009, 06:22 PM   #58
project-D180
but my friend did the same swap 248 intake and exhaust ran fine but today it wouldnt start n sounded like it somethin was getting jammed up when he went to start it n go home..like was gettin caught on somethin or a tooth broke somewhere..?!..would a valve hittin the piston some like that?
Old 08-21-2009, 01:34 PM   #59
Gorilla Unit 33
Gorilla Unit 33 is an unknown quantity at this point
i think this is just one guys opinion from 2+ years ago. As far as i know the 248/248 is the best oem upgrade, especially if you have adjustable cam gears. I plan on putting in my dual 248's next weekend.
Gorilla Unit 33 is offline   Reply With Quote
Old 11-10-2009, 10:35 AM   #60
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
yeah this is old...
To clear some cornfusion, here are some pics of s13 and s14 cams. Take note of the color and the front timing gear pin alignment for intake and exhaust.
Both pics show s13 (91-93) int/exh cams on left & s14 (95 1/2 up) int/exh cams on right.
On The Left
---s13---
(240 intake - 248 exhaust)
Intake = Green (Pin Straight Up With 1st Cam Lobe Straight Up)
Exhaust = Orange (Pin near 9 O'clock or On The Left Side With 1st Cam Lobe Straight Up)
On The Right
---s14--- (232 intake - 232 exhaust)
Intake = Orange (Pin Straight Up With 1st Cam Lobe Straight Up)
Exhaust = Green (Pin near 9 O'clock or On The Left Side With 1st Cam Lobe Straight Up)
~mario
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
