Old 02-03-2007, 10:27 AM   #1
drftr68
drftr68 is an unknown quantity at this point
greddy speed limiter cut install
does anyone know how to install the greddy speed limiter cut into the sr20det ecu. if you do it would be a great help, thanks.
drftr68 is offline   Reply With Quote
Old 02-03-2007, 10:50 AM   #2
kassed33
kassed33 is an unknown quantity at this point
im pretty sure they all install pretty much the same Greddy, HKS, so if you find directions on one that will pretty much get you through it. Or you can cut your speedodomer wire. Ive read that works too, never done it though, i've got a tunned ECU and it gets rid of all that
josh kassed
kassed33 is offline   Reply With Quote
Old 02-03-2007, 11:04 AM   #3
drftr68
yes but ive looked every where to try and find instructions b/c the instructions r in japanese
Old 02-03-2007, 04:48 PM   #4
yokotas13
yokotas13's Avatar
you cant look at pictures?
yokotas13 is offline   Reply With Quote
Old 02-05-2007, 07:04 AM   #5
drftr68
i can but it doesnt say in english what colors go with which wires
Old 02-05-2007, 05:53 PM   #6
drift_ricer
Banned from the Marketplace
drift_ricer is on the path to ruindrift_ricer is on the path to ruin
yeah, I need help with those greddy slc installed too? any1 has any idea? thanks
drift_ricer is offline   Reply With Quote
Old 02-05-2007, 06:30 PM   #7
O3DigitalBath
O3DigitalBath's Avatar
O3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud of
Send a message via AIM to O3DigitalBath
I thought the same as kassed33....thought you could just cut a wire, I would cut a wire before I bought some fancy lil box that did the same thing.
but I could be wrong
O3DigitalBath is offline   Reply With Quote
Old 02-05-2007, 07:33 PM   #8
drftr68
the problem is it still cuts out at 5000 rpms in 5th gear and i have nowhere i can cut my 5th gear sensor at
Old 02-06-2007, 06:58 AM   #9
yokotas13
yokotas13's Avatar
go to apexi, check the RSM diagrams on how to hook it up, should be like hte greddy
