Old 02-07-2007, 06:09 PM   #61
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
touche .
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 02-07-2007, 06:48 PM   #62
steve shadows
steve shadows's Avatar
Im just annoyed because my greddy one did not come with the Blue Anondized Raditor hose interceptor. So im just going to make one from scratch...
Like Me on FaceBook !
Old 02-08-2007, 03:18 PM   #63
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
Originally Posted by steve shadows
I know that.]
I was suggesting putting the line ont one of the nippels just behind the the thermostat that goes to the throttle body instead.
Look at the water circuit in the FSM. It does look like the one hose coming under the intake manifold might work. There are a couple others that you could possibly use, but it depends on where you put it and how much pressure is in those lines. The lower rad hose is obviously the best because it's bigger and it's a direct shot to the water pump. I don't know what size the fitting is on the bottom of whatever expansion tank you have, but the other hoses might be smaller and end up just being more of a restriction.
And besides, making a piece to go in the lower rad hose is easy. Depending on what hose size and fittings, it's real easy. Mine had a 1/2" npt fitting, so a little piece of tube and an aluminum weld on fitting and it was done.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
Old 11-30-2007, 12:14 PM   #64
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
sorry to bring up an old thread, i searched and read the entire thread...
My questions is why hasnt anybody put the "swirl pot" or expansion tank on the drivers side of the car? i mean it seems like it would save tons of headache in mounting, running lines, and other issues. i liked that one of you guys said to mount it maby on the head itself if you have electric fans, which i do, i'm running an S14 sr too btw. I was going to try that but i'm wondering where else i could mount it. I know power steering resovoiar is in the way to put it on the shock tower, i'm running a bottom mount setup with a stock exhaust manifold so i'm going to try and integrate it somewhere over there. If i plumb the air filter into the wheel well down behind the fog lights shouldnt i be able to put it somewhere by the stock overflow tank? Or even mount it on the front support next to the radiator? the only reason i can think that would cause a problem is height over the bleeder location.
Also is it true that if you dont use the "optional" heater hose line that installing it is basically pointless because it wont bleed the system automatically? help me out and pics would be nice, the thread is so old alot of the pics dont work anymore! thanks again
INeedNewTires is offline   Reply With Quote
Old 11-30-2007, 12:28 PM   #65
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
Correct me if I'm over thinking this, but wouldn't you want it away from the hot exhaust manifold side?
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 01-17-2008, 01:24 PM   #66
cdlong
yes, the thread's kinda old, but a wealth of knowledge centered in this thread. i was looking at the overflow tank thread in the advertisers specials forum. they're talking about combining an overflow tank and a swirl pot.
random thought, is the extra radiator cap worth anything? rather than plumb the radiator overflow into the tank and then the swirl pot overflow into the overflow tank, why not just keep the overflow as is, and plumb the bleeder in, and lower radiator hose for the out? a fill point is important, but it could just be a regular sealed cap. i guess it doesn't really get you anywhere except it simplifies construction a bit and eliminates a few connections.
cdlong is offline   Reply With Quote
Old 01-18-2008, 10:54 AM   #67
PoorMans180SX
PoorMans180SX's Avatar
Parts Shop MAX: $60
Found it in the advertiser section.
Thought I'd share in case anyone is still looking. And I know this thread helped me.
Old 01-18-2008, 11:07 AM   #68
steve shadows
coolant temps after 6 laps at bwillow were about 205 max haha
Old 01-18-2008, 05:14 PM   #69
WhiteGLX
WhiteGLX's Avatar
WhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to all
Send a message via AIM to WhiteGLX Send a message via Yahoo to WhiteGLX
with just AL rad and FMIC?
with my old v-mount i used to see 180 on track duiring summer events, seemed unnatural, mmakes me think my gauged was off or i had the wrong sending unit or something. All without this swirl pot thing that everyone loves so much these days.
***NASA HPDE Instructor***
WhiteGLX is offline   Reply With Quote
Old 08-15-2008, 07:44 PM   #70
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
Just an update.
I had trouble installing my tank from PBM due to the fact it was hard to find a fitting for the bleeder bolt. I didn't want to tap the head since I had already put coolant inside and no access to a drill. But I did find an adapter made my memco that fit perfect into my ka24de. Part was m6 to 1/8npt. They have a lot of useful fittings that can be bought in brass or stainless steel.
http://www.mem-co.net/pdf/Memco_Cat_May13.pdf
Works great so far. Just thought I'd let others know incase there were others who didn't want to tap the head and needed alternate decisions.
w0nderbr3ad is offline   Reply With Quote
Old 08-15-2008, 09:08 PM   #71
McRussellPants
Brutal.
New setup on my car the only time it goes over 80c is when I do like ultraburnout.
any sort of airspeed and its back to riding the thermostat.
McRussellPants is offline   Reply With Quote
Old 05-20-2009, 12:31 AM   #72
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
To bring this back up....what if you snapped your bleeder bolt, and also snapped an easy out in side there, could you tap into a different coolant source, like the TB hardlines?
I had looped my Throttle body coolant lines, and it looked like coolant/airbubbles flowed upwards.
Bigsyke is offline   Reply With Quote
Old 05-20-2009, 08:21 AM   #73
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Speaking from the SR point of view, if I broke the bleeder valve on the water neck...I got 2 options. Get another water neck or get one of these:
CLICK HERE!!!
Old 05-21-2009, 03:11 AM   #74
GSXRJJordan
GSXRJJordan's Avatar
Yup, take the opportunity to get an S14 water neck.
Old 05-21-2009, 09:41 AM   #75
INeedNewTires
wasnt someone selling a waterneck adapter recently? added the pre-tapped bung and bleeder valve and everything. why not just get that?
looked through all 5 pages of the advertisers specials, couldn't find it.
Old 05-23-2009, 05:04 PM   #76
Bigsyke
Bigsyke's Avatar
What about for the KA? Couldnt I install that 34mm fitting on the upper hose along with the lower?
Or do you need it where that heater/throttlebody hose junction is, aka OE bleeder bolt?
Old 05-24-2009, 12:41 AM   #77
w0nderbr3ad
Trader Rating: (50)
I'm pretty sure you can put an adapter there in the upper hose and it'd be fine.
