Old 02-08-2007, 02:44 PM   #1
shogun!
shogun!'s Avatar
shogun! is on a distinguished road
Put the S13 flange snug to the Z32 clutch housing and attach the centering plate with four screws
Side view
Top view. Important to align and rotate them like on the picture
If you do not own a TIG-welding machine, you go to the machine shop again and have it carefully welded together, both from the outside and the inside
((((space for picture...after welding))))
My +700hp RS13
shogun! is offline   Reply With Quote
Old 02-08-2007, 02:44 PM   #2
shogun!
shogun!'s Avatar
Reuse the shift stick bracket from the Z32 gearbox. You have to cut out some small triangles from it, bend it to a Z-shape to fit the S13 under body and then weld the cut outs together. (borrowed picture)
The new short shift
A small change of shift stick position compared to the original (borrowed picture)
A plate to cover the hole at the shift stick (borrowed picture)
A bracket to hold the gearbox in place (borrowed picture)
Aligning the gearbox with the rear axle. Put a steel tube in the gearbox, aim it towards the centre of the rear axle flange and find the final position of the gearbox bracket. (borrowed picture)
Side view (borrowed picture)
Front view (borrowed picture)
The prop shaft. Mount the Z32 yoke in the gearbox and the original flange on the rear axle. Measure the centre distance between the loops in the yoke and in the rear flange. Use this measure and go to your local prop shaft supplier and have him to make your new prop shaft. The shaft rotate at about 10.000rpm at max speed so it has to be dimensioned for the forced and also balanced.
(I will edit this post and put in a better photo and necessary dimensions)
My +700hp RS13
Old 02-08-2007, 02:45 PM   #3
shogun!
shogun!'s Avatar
Some more parts belonging to the drive train:
Replaced the internal parts with a really good Deftforce LSD from ATS in Japan
The part number if you plan to buy one yourself. It is an easy exchange; out, move over the tooth ring, clean, mount new sealings, in, oil...ready
OS Giken Twin Disc clutch
Disassembled clutch (discs, pressure plate and flywheel in one lightweight unit)
Before switching over to five stud hub
The new hub set (is on the car now)
New rims on in the garage. Note the nice height of the fender...the 600hp engine is out meeting some new nice parts
My +700hp RS13
Old 02-08-2007, 02:49 PM   #4
luisgonz
luisgonz's Avatar
luisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfectionluisgonz is close to perfection
Send a message via AIM to luisgonz
Please dont post if you have nothing good to say about this.
luisgonz is offline   Reply With Quote
