Old 02-09-2007, 01:47 PM   #10
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
i have them on my car, got them from the front clip.
i had the rotors resurfaced and they work great. not sure how they compare to Z32 though, but you probably cant tell the difference. Lines fit the brakes, as for the rotors, some people say it fits some say it doesnt. Someone told me that they used z32 rotors and the GTS-T calipers and they lost a few mm of pad contact, as in the pad was too far from the center. Maybe the calipers are spaced a bit farther out to accomodate for the larger rotors. Pads are the same so that is the only explaination. Hope that helps
kouki_s14 is offline   Reply With Quote
