Old 02-09-2007, 03:44 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
UBER QUICK HELP- S13=S14 radiator, rad support instal?
First and most important question.
Will an s13 radiator fit a s14 ok? Are there any other nissan radiators you guys have made work, and work well?
Second
How easy/difficult is the upper rad support to install? Bolted or tack welded in? thanks a bunch guys...
gotta240 is offline   Reply With Quote
Old 02-09-2007, 04:59 PM   #2
gotta240
NO ONE knows if s13 rad=s14 rad?
Old 02-09-2007, 05:21 PM   #3
nani
nani is making his/her stupidity well-knownnani is making his/her stupidity well-knownnani is making his/her stupidity well-knownnani is making his/her stupidity well-known
no one sorry
nani is offline   Reply With Quote
Old 02-09-2007, 05:25 PM   #4
projectRDM
projectRDM's Avatar
You know it fits, the upper tabs are further in so you'll just need to make brackets or ziptie it in, everything else is the same.
Core support is welded in. Through the dealer you can buy it in pieces or complete, each piece will need to be spotwelded back in.
Old 02-09-2007, 08:23 PM   #5
gotta240
Haha. I was waiting for your answer. I almost pm'd you but didn't want to bother you.
Thanks. I'll head out and grab an s13 rad from the junkyard tomorrow. Theres not that big of a difference...right? the stock fan will still fit?
Old 02-09-2007, 08:26 PM   #6
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
you are fine on everything except the top mounting brackets, in different spots
KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST
lilredstiffy is offline   Reply With Quote
Old 02-09-2007, 09:16 PM   #7
projectRDM
projectRDM's Avatar
Remember that the S13 radiator is half as thick too, so be prepared for a lot of coolant bleeding.
Old 02-10-2007, 02:05 AM   #8
gotta240
"lot of coolant bleeding"... Sorry, you kinda lost me there. Do you mean the car will overheat very easily(since it prob. holds 1/2 as much coolant if its 1/2 as thick), or are you actually refering to bleeding the air out of the coolant?
thanks again and sorry to make such an easy topic difficult...lol.
Old 02-10-2007, 05:07 AM   #9
projectRDM
projectRDM's Avatar
Bleeding air, that's all. By replacing it you create a huge opening in the cooling system, and it will take a while to bleed it fully.
Old 02-10-2007, 07:54 AM   #10
S14DriftstaiN
S14DriftstaiN's Avatar
S14DriftstaiN is a well-known jackass
If you use the stock s13 fan and shroud the fan will be veeeerrryyy close in the s14. "works fine in my car".
S14DriftstaiN is offline   Reply With Quote
Old 02-10-2007, 05:59 PM   #11
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
yeah the s14 ka takes a while to bleed. and don't rely on the stock gauge to give you a reading
slideways2004 is offline   Reply With Quote
Old 02-10-2007, 06:06 PM   #12
gotta240
recomendations on how to bleed it?
When replacing a radiator i usually just fill it up, turn the motor on and wait till the thermostat opens...i then fill till full. Is there a different better way?
