11-29-2006, 08:04 PM | #121 |
hey guys ive got a 95 S14 with a series 2 rb25det swap and my number 3 coil pack is bad. is there anything stateside with the same style coil pack i can use. i cant find anything that will work. and i also cant find series 2 rb25 or rb26 stock packs for sale. i really dont want to go aftermarket yet any information will be greatly appreciated.
12-04-2006, 02:18 AM | #122 |
Im by no means "new" to RBs, and have owned several RB powered vehicles, but I need a clutch NOW.
I have installed two clutches in all of my time owning these cars, both clutches were bought for a 300zx NA 90-up. They both fit fine on my RB20s. I cannot find a reasonabley priced clutch to fit the horsepower needs of my current RB20. (only a statement) I have seen a couple of companies (seemingly reputable companies) selling clutches and stating that a particular kit of theirs is for a SR20 or a RB20.... My question is, has anyone sat a rb20 clutch and p plate next to that of an sr20? Are they the same? WILL THE SR CLUTCH WORK TOO??????????? Seems too good to be true, any info? Ps. I searched, but nothing crazy...10min at most. |
12-04-2006, 01:26 PM | #123 |
i have a 1990 240sx and i want to go rb20....what will i need to install it...does it bolt up,does it not,...what parts do i need
street drifter 9000! |
12-04-2006, 03:52 PM | #124 | |
Need Installation Help (Motor Swaps, Clutch, Exhaust)? Send me a pm if you need any help at a fraction of the shop price Phoenix Area |
12-08-2006, 09:02 PM | #127 |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
Lets knock all these questions down.
Series 2 coilpacks? No there is no U.S. car that I know of that ran the same thing. There could be now. I suggest you research it a little buy contacting a Nissan dealer and showing them your coilpack for a cross reference. Other than that, look to a importer for spare coilpacks, or even ebay. I have seen them pop up on ebay from time to time. On to the clutch question RB clutches are not the same as SR clutches there is a surface area size difference. And for the camshaft question As far as I know Nismo does not sell camshaft blanks for the RB here in the U.S.. Most of the Nismo parts available for the RB in the U.S. are stuff like gaskets, water pumps,thermostats and oil pumps. Your best bet for cams for the RB are Tomei Poncams which are actually very nice cams. There I hope this at least helps you guys some. Good luck
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
12-12-2006, 12:09 PM | #128 | |
12-13-2006, 12:36 PM | #129 | |
I will be putting out somewhere in the range of 330-340 whp on my next dyno run. I am happy with those numbers I am not shooting for higher because I want my car to be driveable. I am also not trying to build a drag car.
12-13-2006, 12:44 PM | #130 | |
12-15-2006, 01:47 AM | #132 |
hmm.. me saving up them pennies for some -Garrett 2860R-5, very similar to (HKS GT2530's) if anything its a more cost effective set up, bolts right up and should clear fine :-) it will yield an easy 500whp with the right set up and tune.. and yes that will probably be the max you want to step on the stock 26..
01-04-2007, 10:20 PM | #133 |
wiring on a RB25Det on a 91 240 .
i was wondering do i need 2 get custom wiring done for the wiring harness from the motor to the car ? cus i the RB25 with the wiringharness and ECU couldnt i just use the RB ecu on the 240 ? cus im lost and people tell me different things everyday so if any one could help me out a bit . id be happy . |
01-05-2007, 09:15 AM | #134 |
english evades you. anyway, you use the RB ecu and wiring harness....its pretty much common sense when you really think about it. you have to use the ECU that manages/controls the motor that you are putting in.
'89 hatch - RB20 '07 Corvette Z51 |
01-15-2007, 10:41 PM | #135 |
? about all the mount kits that lower the engine, what does this do for oil pan to ground clearance. On mine i just used the r33 cross member and stock mounts moved back 1" and if the engine was much lower it would be below the crossmember.
01-16-2007, 07:46 AM | #136 | |
And for the 20 guys for refrance My boys 20 with a 2530 at 1.2 bar put down 320ps with the rest of the motor stock with a brid ecu. RB20 run <--------CLICK
MY CAR IS MY CAR, YOU DON'T LIKE I DON'T GIVE A SHIT If You are in need of stuff from Japan I can Help you out. Small stuff only, shoot me a PM. If You have bought or buy from me I finally have a review thread CLICK HERE |
01-26-2007, 10:40 AM | #138 |
LAID OUT
This didn't exist, I had the info and another guy needed it, so I made it..
A31 RB20DET Ecu wiring harness pinout with wire colors: Please save & redistribute as needed, I don't know how long we-todd-did-racing will host the image. |
01-26-2007, 10:43 AM | #139 |
LAID OUT
Also some info on Exhaust manifold studs, washers, yokes, nuts:
(qty needed) (12) Exhaust manifold studs - 01151-00471 Courtesy told me this wasn't a valid US part number... But according to Shay @ NismoParts.com, it is valid -- but it's an Infinity part number! Ordered from Shay @ Nismoparts.com (8) Exhaust manifold yokes - 14037-42L01 Readily available Courtesy/Nismoparts.com. 24mm outer diam for cyl 1,2,5,6 (4) Exhaust manifold yokes - 14037-42L02 Readily available Courtesy/Nismoparts.com. 22mm outer diam for cyl 3,4 (12) Exhaust manifold washers 14037-01E00 Readily available Courtesy/Nismoparts.com (12) Exhaust manifold nuts 08912-8401A According to Courtesy "97812-8401A" is is not a valid PN. I looked the nuts up in FAST and found a new PN, "08912-84010". Shay @ Nismoparts.com informed me that "08912-8401A" is the superseded PN. Readily available Courtesy/Nismoparts.com These parts are all $.60 to $1.70 each, so figure roughly $1/each on average. 12 studs + 12 yokes + 12 washers + 12 nuts = 48 parts @ ~$1 ea = $50 plus shipping for a full set. |
01-26-2007, 10:45 AM | #140 |
LAID OUT
Nismo makes r32/r33/r34 motor mounts for use with with oem mount brackets and x-member. For R32 2WD: PN 11220-RS585 you'll need two:
http://www.nengun.com/nismo/engine-mounts The Nismo KA trans mount is apparently the same as the RB trans mount. I plan on re-using mine (thanks drift_freaq), if it's different for any reason I'll update the post. |
02-06-2007, 09:36 AM | #142 | |
LAID OUT
RB25 water pump on RB20 does not work properly. Check out the pictures and write up below...
Cross posted from my post on the other RB boards. Quote:
02-07-2007, 10:29 PM | #143 | |
RB20 Turbo Upgrade, Dyno Results The one you want to look around in: RB25 Turbo Upgrade, Dyno Results And for the surprisingly less rare RB26 people RB26 Turbo Upgrade, Dyno Results Gotta love the Aussies... Hope it helps. |
02-20-2007, 05:58 PM | #148 | |
02-20-2007, 10:13 PM | #150 |
rb25det series one uses an ignitor pack/chip and a series two has the ignitor built into the coils. thats is the most noticeable difference, the MAFS are different too i believe.
