Old 02-22-2007, 07:47 PM   #1
GR8WHITE
GR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-known
s13 Exhaust Smacking Floorboard Help
Just wanted to know if anyone else has had this same problem. I have a s13 coupe with a blacktop sr20 with greddy turbo elbow, 3" flex downpipe, cat delete pipe, and apexi noir exhaust. The problem I am having is the exhaust is hitting on the floorboard where the drivers side right rear seat stud is, the exhaust is literally less than 1/2 an inch away from the body. I bought the nismo exhaust hangers and it seems like it made it worse by keeping the exhaust closer to the bottom of the car. Does anyone know what I can do to remedy this? Maybe try to bend the hangers? Thanks
GR8WHITE is offline   Reply With Quote
Old 02-22-2007, 08:30 PM   #2
McRussellPants
Mine used to hit up by the pedals.
shrug.
I got a new motor and it doesn't do it anymore.
McRussellPants is offline   Reply With Quote
Old 02-22-2007, 09:39 PM   #3
GSXRJJordan
GSXRJJordan's Avatar
Hey, I've got the same exhaust, and yeah right behind the first muffler I noticed that I'm hitting a little bit - basically whenever I swing a hard right, or slide through a right hand drift, it hits the floorboard. I only noticed it happening after I actually attached the hanger right by the rear axle.
I'm guessing it's the hanger at the very back that angles the exhaust a little bit. I'm not too worried about it, I've got bigger issues (car's low enough to scrape the downpipe, muffler, and piping, and it's all pretty tucked). Nice exhaust though, huh?
Old 02-22-2007, 10:25 PM   #4
vw_nissan
vw_nissan is an unknown quantity at this point
So I am not the only one with this problem then.....new exhaust hangers don't help huh......
The exhaust hit the seats stud like crazy especially during rainy days....the car will just be idling at the light, but the exhaust rattles like an exhaust hanger is missing.....drives me nuts.....
I have an Apex N1 btw.
vw_nissan is offline   Reply With Quote
Old 02-22-2007, 10:28 PM   #5
gonzoes14k
gonzoes14k is on a distinguished road
Send a message via AIM to gonzoes14k Send a message via Yahoo to gonzoes14k
i had this issues with mine, i put new hangers in rear and it semi-fixed the problem, but under as stated when turning hard or decel i can hear it.
"To establish the sports car, you have to race it," Zora Arkus-Duntov
gonzoes14k is offline   Reply With Quote
Old 02-23-2007, 07:34 AM   #6
AwhiteS13
AwhiteS13's Avatar
AwhiteS13 is an unknown quantity at this point
I had the same problem with the N1, Just cut the seat bolt and you'll be fine
AwhiteS13 is offline   Reply With Quote
Old 02-23-2007, 07:40 AM   #7
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
I had a problem with mine bouncing off the driveshaft 1pc and sounding like it was hitting under the car. Sure it's not the shaft?
Eye on the Prize
TheWolf is offline   Reply With Quote
Old 02-23-2007, 08:21 AM   #8
vw_nissan
But it's not the bolt that is coming out right? It's the bolt seating that is coming out, but if you cut it, you wouldn't be able to put new bolts in anymore, no?
Old 02-23-2007, 08:34 AM   #9
g6civcx
g6civcx's Avatar
New motor mounts and gearbox mount.
Old 02-23-2007, 10:17 AM   #10
-=RS13=-
-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of-=RS13=- has much to be proud of
BFH to the floorboards
Built by myself, Not by a shop and defintaly not bought. FTUW
-=RS13=- is offline   Reply With Quote
Old 02-23-2007, 02:00 PM   #11
GR8WHITE
I HAVE THE NISMO MOTOR MOUNTS AND TRANNY MOUNT, AND I HAVE ALREADY CUT THE BOLT OFF. IT ESPECIALLY HITS WHEN THE ROAD STARTS GETTING A LITTLE BUMPY AND WHEN I DRIVE THE CANYON HOME IT HITS WHEN I MAKE RIGHT TURNS. MAYBE I AM GOIN TO TRY AND BEND THE EXHAUST HANGERS A LITTLE BIT, I ALSO HAVE TEIN SUPER DRIFT COILOVERS AND THEY ARE SUPER STIFF SO I AM SURE THAT DOES NOT HELP. BTW THE NOIR EXHAUST IS AWESOME! SORRY ABOUT THE CAPS
Old 02-27-2007, 07:25 PM   #12
GR8WHITE
allright what i ended up doing is loosening the exhaust from the turbo elbow to the beginning of the apexi exhaust and there was play in the downpipe and cat delete pipe bolts, where the nuts and bolts attach the holes for the bolts on the pipes were much larger than the diameter of the bolts so i loosened it up and moved the exhaust in the direction away from the floorboard and it fixed the banging by about 98%
Old 02-27-2007, 07:29 PM   #13
Jesses240
Jesses240's Avatar
Jesses240 is making a name for him/her selfJesses240 is making a name for him/her selfJesses240 is making a name for him/her self
I was gonna say take it all apart and put it back together....
but you already did that
--Jesse R33
Jesses240 is offline   Reply With Quote
