Old 03-07-2007, 10:37 PM   #1
yokotas13
yokotas13's Avatar
dropped a cylinder rb25det
Ok heres the problem
I hit a bump, and BAM
Shit started smoking, adn through elimination its #1
WHen you unplug the fuel injector it is fine, smoke goes away
plug it in, smoke city
it runs on 5
when i plug #1 injector in, it wants to die in like 2 seconds flat, and will only stay running, barely with some throttle.
all 6 plugs have same appearance
all 6 cylinders have same compression, wiht no loss within 5 minutes of pressure.
i cant figure this shit out.
any ideas?
I also swapped #1 and #2 fuel injectors, same problem
i haevnt done the coil packs yet.
yokotas13 is offline   Reply With Quote
Old 03-07-2007, 10:41 PM   #2
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
dam that must have been some bump you hit
i say check the coilpack and plug.
maybe even a valve got bent?
that would be my best guess
kouki_s14 is offline   Reply With Quote
Old 03-07-2007, 10:45 PM   #3
yokotas13
yokotas13's Avatar
i was thinking valve also, i got a weird tapping going on. im going to pull the valve covers this weekend when i have more help and the intercooler off for the FMIC changeover....
i gota find a coilpack though....
Old 03-08-2007, 12:22 AM   #4
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
Did you drive off a clif? haha, Thats heck of a bump to cause that. Yeah i would check the coil and if not that then check for a bent vavle.
Bryants95240sx is offline   Reply With Quote
Old 03-08-2007, 05:13 AM   #5
liv2drift045
liv2drift045's Avatar
liv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfection
Send a message via AIM to liv2drift045 Send a message via MSN to liv2drift045
That sucks bro. I would of thought coilpack as well.
StreetSliders.Blogspot.com
liv2drift045 is offline   Reply With Quote
Old 03-08-2007, 05:54 AM   #6
yokotas13
yokotas13's Avatar
get on AIM fag
Old 03-08-2007, 09:23 AM   #7
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
Why is everyone saying it's the coil? I don't get that at all. He is saying once he plugs in the FUEL is when it starts smoking. Oh yeah, where is the smoke coming from?
I think that there could be a short in the fuel injector wiring and it's keeping the fuel injector on, thus flooding that cylinder and affecting the other cylinders. One bad coil can't do anything to the rest of hte cylinders. And keep in mind that he keeps the coil plugged in the whole time! So I definately think this issue is fuel related.
But yeah, got a picture of the bump? lol
shayrgob240 is offline   Reply With Quote
Old 03-08-2007, 09:28 AM   #8
chmercer
chmercer's Avatar
if the injector is just pouring in it will make smoke at idle, like white smoke looks like coolant but dosent smell like it. im assuming either ripped injector gasket or bad injector?
edit just saw you swapped injectors. hmm id be 100% positive its not the o rings, ive pinched the o rings quite a few times, but other than that, what everybody else says
chmercer is offline   Reply With Quote
Old 03-08-2007, 09:42 AM   #9
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Damn that sucks.
Do a Leakdown test to see if the rings and valve seat and HG are ok. Edit: See you already did a compression check..
When you swapped the injectors, did you leave them both plugged in? Because if the original injector is leaking and you plug it in it'll smoke regardless of what cylinder it's in... Unless you swapped the injector and only plugged in the "new" injector and left the original unplugged on the other cylinder. I would probably send the injectors out for flow testing and ultrasonic cleaning if the leakdown test shows good.
GL dude.
MELLO*SOS is offline   Reply With Quote
Old 03-08-2007, 10:15 AM   #10
shayrgob240
GL dude.
good point!
gasdgasdsdgs
Old 03-08-2007, 11:15 AM   #11
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
It sounds like plugging the "bad" injector in is whats causing the white smoke. You should find another injector to test with or have your injectors rebuilt with new orings and insulators/spacers.
GL
Old 03-08-2007, 07:01 PM   #12
yokotas13
yokotas13's Avatar
when i did the injectors
I left the #2 cylinder deasctivated not plugged in so it wouldnt be a factor
But it fixed itself today
i dont know how
But i have 550s and a new coilpack on the way in case.
Old 03-08-2007, 07:39 PM   #13
mrmephistopheles
mrmephistopheles's Avatar
SAFC.
j/k i have no idea.
Originally Posted by PHLIP
Old 03-09-2007, 12:37 AM   #14
liv2drift045
Originally Posted by mrmephistopheles
SAFC.
j/k i have no idea.
hahaha faulty wiring/operator error
Old 03-09-2007, 07:51 PM   #15
skate07
skate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-known
best guess would be wiring or plugs loose?
skate07 is offline   Reply With Quote
Old 03-10-2007, 09:24 AM   #16
ECR33S14
ECR33S14's Avatar
ECR33S14 is an unknown quantity at this point
Send a message via AIM to ECR33S14
if a coilpack was fucked the car would run like shit. you should be able to feel/hear a stumble throughout the RPM range. and it would smoke like fuel if a coilpack was fried because its not burning the fuel.
95 Zenki-RB25 swap with a couple of things
95 Zenki-SR on the way
ECR33S14 is offline   Reply With Quote
Old 03-10-2007, 08:11 PM   #17
yokotas13
yokotas13's Avatar
it sa coilpack, we took it off and hooked it up to a tester, and it snot putting out full voltage all the time, i have another one on the way
