![]() i really want to throw in a SR20DET red top on my s13 coupe. i got a estimate from a shop for 2,800 is that too much or a good deal?
He said it came with this!! (sr20det,new fuel pump,new air filter everything else is oem) |
![]() Join Date: Jun 2006
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
if thats for just a motor set, fuck that you can get them cheaper, but if thats installed its a pretty good price. seems to be about $800, which isnt bad because i had a shop try to charge me $1200 for labor.
![]() Join Date: Jul 2006
Motorset from HeavyThrottle: $2550
Motorset from Enjuku: $2299 I'm not sure of the quality of Heavy Throttles but all of the ones from Enjuku I've seen were amazing. Heavy Throttle is highly regarded though so I'm sure they're nice. Enjuku details all of the motors before they give them to you. $2800 would be too much for the motorset and I kind of doubt that it's $2800 for the motor and installation. I'd be worried about the quality.
BitDestroyer.com |
RNDfactory has a good price on SR's installed. Go to www.rndfactory.com and give them a call. They have some motors coming in at the end of the month. My friend and I will be picking up one for his car.
![]() Join Date: Mar 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
i would change the clutch and water pump while the motor is out. It will save you troubles down the road. And also is a good idea on a motor that will have been sitting around.
http://s165.photobucket.com/albums/u63/ajhartma/ 1990 240sx hatch....currently monster truck status, with sunken battleships. ![]() *Junkyard Scavenger* |
#15 |
![]() Join Date: Sep 2005
Ya, for sure do the clutch while you have the motor out, it is so much easier. Motor and tranny mounts are also good options. Look if there is anything else that is needed, possibly new turbo gaskets. Also any other parts you were planning on upgrading soon after install, just do it all at once.
#16 | |
![]() Join Date: Jul 2005
Trader Rating: (29)
that $2,800 better be with installation....
#17 |
![]() Join Date: Jun 2004
itt why I dont do motorswaps anymore.
[email protected] |
#18 | |
Trader Rating: (29)
#19 |
I would hate to sound like a prick.. but honestly.. if you need to ask man, you aren't ready. if you cant do a swap yourself, then at the very least you should know whats included in the swap, and what other shit should be swapped out...
#20 | |
![]() Quote:
#21 |
![]() Join Date: Jan 2007
DJ_Sunrise is too harsh. You do not need to have knowledge of swapping engines to get an SR20 swap. If that was true, 2/3rds of sr20 owners would not exist. On the other hand, you have to have some common sense about engine maintainence. I reccomend you get a blacktop since its newer and has a better chance of lasting you. Also, get a clip that is BONE STOCK to ensure it has not been abused. Important thing to know is if the swap includes the sr20det radiator. The KA radiator has the top opening on the opposite end. Good luck with your decision.
#22 |
not only general knowledge about engine maintenance is needed to perform a swap but also an overall knowledge about engines themselves, wiring and what everything does will help as well. There will always be some sort of learning involved in anything you do.
#23 |
If you have the money, get it serviced regularly by an experienced shop, they should be able to keep you on the up and up. SR20's are awesome reliable engines when proper maintenance is taken.
I have seen tons of Clips with Rolled ODO's (35k Kilos, and the steering wheel is worn to death by man handling.. gtfo). Also alot of SR's get reverted to stock before they are cut up and shipped. I would check metal flakes in the oil, and scaring on the cam lobes to judge engine wear. The largest problem with SR owners, is not being able to bleed the air from the coolant system.
[email protected] |
#24 | ||
![]() Join Date: Jul 2003
![]() Quote:
HouseBuyers365.com Quote:
#25 |
thats not a bad deal at all if it includes labor. if i were you, id inquire what they have avail for a s13 blacktop, or even a s14 notchtop and opt for that instead. change the clutch while its easy to do so. the water pump is cheap, so might as well take care of that at the same time.
personally I'd replace a lot more things for the sake of reliability (timing belts, gaskets, sparkplugs), diagnostics (boost, oil pressure guages, maybe even splurge on a wideband) and ease of upgrading parts in the future (fmic, dp, exhaust). The SR reliability parts i put in at the same time cost a bit more than my s14 clip itself, but thats just me. just search around, there should be plenty of resources covering this on here and other nissan sites. i'd highly recommend that if you can save up and do things right the first time around, you're going to save yourself a lot of $$$ and headaches in the long run. good luck! ![]() Last edited by ronmcdon; 03-19-2007 at 12:51 PM.. |
#26 |
I always replace the timing belt(s) on the SR!!!
[email protected] |
#27 |
Thanks ammer!! I hate when people on these chats think just cuz they know everthing about sr20 that we should too, thats why im asking if i new then i would not ask...well thanks everone that help me get some more ideas on the swap. im for sure going to use your ideas.
thanks again, Me. |
#29 |
Just for the record, the above statement about the timing belt, was me being sarcastic.
[email protected] |
