Old 08-16-2002, 09:17 PM   #1
aqwkmf
aqwkmf is an unknown quantity at this point
i tried to downshift from 5th to 3rd at ~45 mph....grind. i seen another post about this before. is this a common problem with our cars?
aqwkmf is offline   Reply With Quote
Old 08-16-2002, 09:21 PM   #2
Annoying Eric
Annoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura aboutAnnoying Eric has a spectacular aura about
Send a message via AIM to Annoying Eric
I have a question why were you in 5th gear at 45mph?
Annoying Eric is offline   Reply With Quote
Old 08-16-2002, 09:23 PM   #3
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
I personally like to go through all the gears anyway just because it gives me a better feel of how much of a blip I need to give the gas pedal to match the revs.
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 08-16-2002, 09:34 PM   #4
aqwkmf
casual driving
15mph shift to 2nd gear
25mph shift to  3rd gear
35mph shift to 4th gear
45+mph shift to 5th gear (aka overdrive) saves gas by locking the torque converter and lowering rpms
taken from owners manual
my racing choices
2nd shift to 30-35
3rd shift to 50-60
4th shift to ? never redlined 3rd gear yet
i like ur method transient....ill use it.....im more worried about my can than the time
Old 08-16-2002, 11:03 PM   #5
Silviaspeed
Silviaspeed is an unknown quantity at this point
Send a message via AIM to Silviaspeed
It can be done, you just have to make sure you match the rpm's to the gear.  If you grinded, you weren't revving the engine enough to match the synchros.  I can do it fairly easily, you just need to be familiar with what speed is best for which gear.  For instance coming up to my block i'll be in 4th, as i come up to my block I apply the brake......and once I reach a certain point I shift to second and make the turn.
www.ImportFanatiX.com
-95 240SX
-S14 blacktop
Silviaspeed is offline   Reply With Quote
Old 08-17-2002, 11:43 AM   #6
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
If you're just downshifting, you should be able to get it in to 3 at 45 mph fine.  That'll put you at what 3750-4000rpm?
Well, if you're double clutching to rev-match, here's a tip:  after clutch and putting it in neutral, push the clutch in and blip the throttle to an estimated rpm at the speed you're driving while slightly pushing your shifter in the gear you want.  When you've rev-matched, the shifter should slide in to the gear easily.
Dunno if I explained that correctly, it's too early in the morning, so correct me if I missed anything.
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 08-17-2002, 11:53 AM   #7
ruf
ruf's Avatar
ruf is an unknown quantity at this point
Even if you revmatch, you may still grind. You need to double-clutch to spin up the idlers in the transmission to the matching speed as well. Rev matching with the clutch in will only match engine RPM, not transmission gears.
ruf is offline   Reply With Quote
Old 08-17-2002, 12:52 PM   #8
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
sometimes double clutching won't help my transmission. i have to push in the clutch, take it out of 5th, go to 2nd gear, then 3rd, rev match (to save wear on the clutch) then let out.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 08-17-2002, 09:43 PM   #9
aqwkmf
yea trust me i was't casual downshifting <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
Old 08-17-2002, 10:51 PM   #10
tnord
tnord's Avatar
tnord is an unknown quantity at this point
sheeeet...........i beeyotched that linkage down duece cogs from da figgidy-five yo, and dat's at double 40's. it ain't no thang.
tnord is offline   Reply With Quote
Old 08-17-2002, 11:08 PM   #11
aqwkmf
hey tnord...do u mind if i steal that phrase for my sig?
Old 08-17-2002, 11:18 PM   #12
tnord
tnord's Avatar
go ahead........just so long as you give me credit for it, as i see you already have.
Old 08-17-2002, 11:21 PM   #13
DuffMan
DuffMan's Avatar
3rd gear is just messed up on our cars. Next time go to 2nd &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>
Old 08-18-2002, 02:08 PM   #14
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
i never had any problems like that on my s13. and i usually go into 5th gear at 39-40 mph no problem
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 08-18-2002, 07:35 PM   #15
my240likenoother
my240likenoother is an unknown quantity at this point
Send a message via Yahoo to my240likenoother
i have had no pob there eather
but i always mach up the rmp when downshifting
your sincros could be shot <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>
my240likenoother is offline   Reply With Quote
Old 08-19-2002, 02:51 AM   #16
PabloHoney
PabloHoney is an unknown quantity at this point
Send a message via ICQ to PabloHoney
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (aqwkmf @ Aug. 16 2002,10:34)</td></tr><tr><td id="QUOTE">casual driving
taken from owners manual</td></tr></table><span id='postcolor'>
Hmmm, the owners manual is dumb if that is a quote from it. If you have 5 speeds, you have a manual obviously, and if you have a manual, I would love to see you lock up your torque converter =) hahahaha, that's damn funny.
'95 240sx
5 spd
LSD
Front STB
Clutchmasters Stage I
5-lug swap
Z32 brakes
Z32 wheels
225/50 Yokohama AVS ES100
Whiteline Adjustable Rear Anti-sway bar
PabloHoney is offline   Reply With Quote
Old 08-19-2002, 07:11 AM   #17
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
It helps to guide it from 5-4-3 (clutch in, brake, 5-4-3, clutch out. &nbsp;I think it's tricky to hit 3rd just right unless you guide it that way. &nbsp;Doable - but, for me, slower and more likely to get a refusal b/c I'm too close to 1st &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/nervous.gif" border="0" valign="absmiddle" alt=':nervous:'> &nbsp;or 5th.
HippoSleek is offline   Reply With Quote
