Old 08-17-2002, 05:08 PM   #1
phatsx
phatsx's Avatar
phatsx is an unknown quantity at this point
Does anyone know witch wire I need to cut to get rid of the  speed limiter (if I can even do it) on my 96' 240.  My friend cut a wire on his s13 and it removed the limiter succesfully, but he doesnt remember witch wire it was.
Thanks,
Ted
Nsport turbo kit, JWT ecu, JWT fuel rail, MSD 72lb injectors, Cobra MAF,SPEC clutch, KYB agx shocks, Eibach Pro springs,Apexi GT Spec exhaust, 18x8 Konig flight wheels, BFG KDW 265/35/18 (rear) Dunlop fm901 225/40/18 (front), indash tv and dvd player with ps2 and some more stuff that I probally can't remember
1/4 Mile:13.9 @ 105 / 7lbs of boost w/o JWT mods
http://www.eframes.com/default.asp?g...bum=38203.2910
phatsx is offline   Reply With Quote
Old 08-17-2002, 05:27 PM   #2
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
dont be stupid and start cutting wires..do it right or dont do it at all..get ur ECU reprogramed..or buy a new ECU JWT or something..i recommend u start cutting wires...i would rather jack up my car and take out the senors for my 4th and 5th gear..rather than cutting wires..if u wanna know more..visit
www.240sx.org
in the FAQ or something they tell u how to do it
SilviaDriver is offline   Reply With Quote
Old 08-17-2002, 05:27 PM   #3
sileighty
sileighty is an unknown quantity at this point
how do you remove a speed limiter for a sr20det s13?
sileighty is offline   Reply With Quote
Old 08-17-2002, 05:35 PM   #4
phatsx
phatsx's Avatar
It's a 93 240sx ka. The s13 is the chassis designation. I have plans to get the jwt ecu, injectors, maf, and fuel rail but I just put 4g's in the turbo kit. My friend cut the wire and removed his speed limiter with no ill effects at all now whats wrong with that? I won't be able to afford the mods till next april when I do internals and up the boost to 22psi.
Old 08-18-2002, 03:40 AM   #5
HKrpS13
HKrpS13 is an unknown quantity at this point
Send a message via AIM to HKrpS13
Whats wrong? Whats the point of going so fast? Your going to kill someone. 120 mph is fast enough. Besides where the hell are you going to bust something above 120 mph?
HKrpS13 is offline   Reply With Quote
Old 08-18-2002, 04:24 AM   #6
Tyler Durdan
Tyler Durdan's Avatar
Tyler Durdan is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (HKrpS13 @ Aug. 17 2002,05:40)</td></tr><tr><td id="QUOTE">Whats wrong? Whats the point of going so fast? Your going to kill someone. 120 mph is fast enough. Besides where the hell are you going to bust something above 120 mph?</td></tr></table><span id='postcolor'>
Who are you....his mother. &nbsp;I believe its the yellow wire that goes into the ecu. &nbsp;Do a search, and you should come up with the info. &nbsp;I don't know if this has been tried on the 95 and up 240's...just heard of people doing it on the s13.
&quot;Pure adrenaline attached to a license plate. &nbsp;Isn't it time to experience one yourself?&quot; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; -Dan Gurney
Turbo for Sale
Tyler Durdan is offline   Reply With Quote
Old 08-18-2002, 01:01 PM   #7
bbp
bbp's Avatar
bbp is an unknown quantity at this point
there are 3 plugs on the side of the manual tranny. &nbsp;one is a reverse indicator, one is a 5th gear indicator and the third is the speedometer. &nbsp;unplug the 5th gear sensor (the one in the middle). &nbsp;the computer reads RPM and gear selection. &nbsp;when you reach around 5500 in 5th gear it will trip a rev limiter.
don't cut any wires, they all have plugs &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
bbp is offline   Reply With Quote
Old 08-18-2002, 03:52 PM   #8
MarketPlayer
MarketPlayer is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (bbp @ Aug. 18 2002,2:01)</td></tr><tr><td id="QUOTE">there are 3 plugs on the side of the manual tranny. one is a reverse indicator, one is a 5th gear indicator and the third is the speedometer. unplug the 5th gear sensor (the one in the middle). the computer reads RPM and gear selection. when you reach around 5500 in 5th gear it will trip a rev limiter.
don't cut any wires, they all have plugs <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
Is that for an S13 or S14? &nbsp;I have no idea if the tranny sensors changed through the years! &nbsp;My reverse sensor is busted off on my tranny so when i am cruising down the road my reverse lights will come on by themselves, but it is a bitch when you are in a parking lot trying to back out b/c no one can tell.
I also agree w/ the "Mother" comment. &nbsp;If you don't want to answer the question for him, then just don't say anything!
MarketPlayer is offline   Reply With Quote
Old 08-18-2002, 07:41 PM   #9
phatsx
phatsx's Avatar
Thanks for all the help. &nbsp;About the mother comment, it's not that i'm going to go that fast but it's nice to know that I can. &nbsp;What is the purpose in putting performance mods on you car if you can't test the full potential of your cars power.
Old 08-19-2002, 12:12 AM   #10
Mtt22
Mtt22 is an unknown quantity at this point
just for some info, i heard of someone doing the one where you remove the sensors for 4th and 5th on the tranny and then he oculdnt even use them, the only one ive heard works is cutting the wire, its on 240sx.org in the faq which one and everything, but i have no idea, do at your own risk, has anyone on here done this to there car? cause it surely is amazing annoying, i had a cherokee(or however you spell it) try to race me on the highway, i smoked him up to like 190km then the damned limitor cut me off and he caught up and passed me.....a fucken cherokee!!!!!!! &nbsp; Anyway, i shouldnt have been going that fast anyway, but wtf
Matt
&quot;andy offers kevin pudding at 9, if andy is 7 years older then pudding than how many liters of andy does it take to get to detroit?&quot;
&quot;There are 3 types of people in this world. People who can count, and people who cant..&quot;
&quot;&quot;Save the Whales&quot; (Trade them for valuable prizes)&quot;
Mtt22 is offline   Reply With Quote
Old 08-19-2002, 06:53 AM   #11
bbp
bbp's Avatar
I have removed the 5th gear sensor plug on my track car. &nbsp;I was hitting the limiter on the back straight at Mid Ohio. &nbsp;I am still able to use 5th gear(? if that's what you meant?).
Old 08-19-2002, 10:58 AM   #12
S14 Drift&#33;
S14 Drift&#33; is an unknown quantity at this point
On my S14 95, (SE Canadian) I unplugged the 5th gear sensor...and it didn't change anything....
For everyone who think that you can just cut the VSS wire....yes you can, but the ECU will be in a kind of safe mode... so it won't play with timming and other things....so I would say Don't Do it!
Buy a HKS FCD....or upgrade the chip.
S14 Drift&#33; is offline   Reply With Quote
Old 08-19-2002, 02:37 PM   #13
sileighty
i just want to get rid of the speed limiter because i wanna hit 140 on the streets near schools... i am tired of running only 115mph
Old 08-19-2002, 04:52 PM   #14
Tekryder
Tekryder's Avatar
Tekryder is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sileighty @ Aug. 19 2002,3:37)</td></tr><tr><td id="QUOTE">i just want to get rid of the speed limiter because i wanna hit 140 on the streets near schools... i am tired of running only 115mph</td></tr></table><span id='postcolor'>
Geez man, near schools?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>? You should have left that part out.......
Shift_Played Out
Tekryder is offline   Reply With Quote
Old 08-19-2002, 11:50 PM   #15
jeffmort3235
jeffmort3235 is an unknown quantity at this point
this is the funniest fuckin post I have seen in a while. I agree I wanna take off my speed limiter too. I &nbsp;beat an escalade 3 times all on 1 highway but we both maxed out at 120 so it was good cuz he didn't take me when we got to 120, but I could have fuckin blew him away real bad if frigin nissan didn't make the car go so fuckin slow, I mean come on 120 I do that in my driveway!
jeffmort3235 is offline   Reply With Quote
Old 08-20-2002, 06:02 AM   #16
junia
junia is an unknown quantity at this point
Send a message via Yahoo to junia
Hmmm... I don't remember my silvia ever having a speed limiter. &nbsp;The speedometer only went up to 180kph and it was supposed to kick in there but I used to take it passed that all the way to about 7000rpm in fifth gear(whatever speed that is). &nbsp;Why don't you do whatever other mods you have planned for your car first and then afterwards just have your ECU reprogrammed for that and at the same time have you speed limiter removed and the revlimiter raised to whatever you want to. &nbsp;Thats just my suggestion.
1990 Nissan 240sx hatchback, 1991 Nissan Silvia K's PS13, 1978 Toyota Corolla KE-30
junia is offline   Reply With Quote
Old 08-20-2002, 06:56 AM   #17
MyFirst240SX
MyFirst240SX is an unknown quantity at this point
cute ecu wires randomly untill it achieves the desired effect. &nbsp;It would be great entertanment seeing many little things go out.
It is better to drive a Slow car fast than to drive a fast Car slow!
'89 FastBack 5spd: Intake/Exhaust,Strut Bars and JL15.
'90 Parts car/Some day drag car.
MyFirst240SX is offline   Reply With Quote
Old 08-20-2002, 09:54 AM   #18
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Tekryder @ Aug. 19 2002,5:52)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sileighty @ Aug. 19 2002,3:37)</td></tr><tr><td id="QUOTE">i just want to get rid of the speed limiter because i wanna hit 140 on the streets near schools... i am tired of running only 115mph</td></tr></table><span id='postcolor'>
Geez man, near schools?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>? You should have left that part out.......</td></tr></table><span id='postcolor'>
Tek, I'm pretty sure that was supposed to be taken as a joke. &nbsp;Relax. &nbsp;No dead babies here.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-20-2002, 10:05 AM   #19
junia
How fast would the 240sx go with the stock engine? &nbsp;Maybe minor mods like intake exhaust and weight reduction but nothing else.
Old 08-20-2002, 01:04 PM   #20
MarketPlayer
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (junia @ Aug. 20 2002,11:05)</td></tr><tr><td id="QUOTE">How fast would the 240sx go with the stock engine? Maybe minor mods like intake exhaust and weight reduction but nothing else.</td></tr></table><span id='postcolor'>
I would have to say that weight reduction would be a bad thing or do nothing o increase top end speed. &nbsp;I would say that with 155hp to the ground (assuming you have I/H/E) you will hit the max speed at about 135-140<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>???
Old 08-20-2002, 02:47 PM   #21
phatsx
phatsx's Avatar
I would just wait and do the JWT upgrade (no $&#036<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> and not worry about removing the speed limiter but it seems like now that I have a turbo, I just want to destroy every mustang and Honda owners pride on the road but if I have to stop at 120, it wont make mustang boy feel like the bitch that I want him to feel like &nbsp;after he experiences what a 240 can do to his pride!!!
Old 08-20-2002, 04:15 PM   #22
Mtt22
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (MarketPlayer @ Aug. 20 2002,2:04)</td></tr><tr><td id="QUOTE"><!--QuoteBegin--junia+Aug. 20 2002,11<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (junia @ Aug. 20 2002,11<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>5)</td></tr><tr><td id="QUOTE">How fast would the 240sx go with the stock engine? Maybe minor mods like intake exhaust and weight reduction but nothing else.</td></tr></table><span id='postcolor'>
I would have to say that weight reduction would be a bad thing or do nothing o increase top end speed. I would say that with 155hp to the ground (assuming you have I/H/E) you will hit the max speed at about 135-140<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>???</td></tr></table><span id='postcolor'>
the theoretical top speed is 158, prolly closer to 145 at max
Matt
Old 08-20-2002, 08:05 PM   #23
Alias
Alias is an unknown quantity at this point
Someone here posted a link to a program to tell max speed in each gear. According to that its 162MPH @ 7000RPM. Of course we don't have enough power to do that much.....
Alias is offline   Reply With Quote
