Old 08-19-2002, 09:38 AM   #8
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (HaLo @ Aug. 17 2002,6:48)</td></tr><tr><td id="QUOTE">No problem Coastek!
As for wiring those lights, here is the easiest way to light them up all the time:
1. Pass a new wire from behind the fuse box to the daytime lights.
2. Cut the cigarette lighter wire and wire the new Daytime lights wire to the cigarette lighter wire on the fuse box side. That way, your daytime lights are on your accessory key contact.
3. Cut the Parking lamps wire and connect the cigarette lighter wire to that wire on the fuse box side.
4. Invert fuses. (Cig lighter is 15A, Park Lamp is 10A)
And voilÃ*! You're done!
Unique and blinding look.</td></tr></table><span id='postcolor'>
hey are u talking bout the fuse box un the footwell of the cockpit of is ther another one somewhere else.. that seems kinda hard.well i should be pming u this fri. halo.. i get paid this thurs.. ok.. later
thanx
CoasTek240 is offline   Reply With Quote
