Old 03-22-2007, 11:49 PM   #1
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Temp. Guage Freaking Out???(vid)
Ok, so recently my temp gauge inside my car has been freaking out and acting very erratic and strange. It'll jump up and down over a matter of seconds. It'll usually just hang around the C and dance around a lil bit, just bouncing slightly. If you look at the video, just watch the last like 30 seconds of it to see that. Other than that, it just acts strange and doesnt show the actual reading at all. It'll read normal temperature at idle, but when i give it gas, the temp guage fluctuates.
This was on a 120mile trip that i took the video, i had been driving the car for approximately already 45 minutes on the highway at the time the video doing roughly 70-80mph consistently.
Sorry for the obnoxious, shitty sound. Apparently my point and shoot camera doesnt like doing video inside a car thats doing 80mph.
http://www.youtube.com/watch?v=sKksFWgyHp0
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 03-22-2007, 11:52 PM   #2
jrmiller84
jrmiller84's Avatar
jrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond repute
Send a message via AIM to jrmiller84
My car did the same thing, turned out to be a bad gauge. I could flick the cluster and it would settle back down. From what I understand, the temp gauge sucks in 240's. Possibly check the wiring or the sensor since it does it when you rev.
It's worth getting an aftermarket gauge. They will be more accurate than the stock gauge.
BitDestroyer.com
jrmiller84 is offline   Reply With Quote
Old 03-22-2007, 11:55 PM   #3
YucA
YucA's Avatar
YucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of light
check the wire going to the sending unit, or grounds... Best thing would be to just invest in an after market gauge. Stock gauge is mickey mouse anyways, and not worth much...
YucA is offline   Reply With Quote
Old 03-22-2007, 11:56 PM   #4
BlackZenkiS14
Yea, i was hoping you wouldnt say that haha. I dont want to spend anymore damn money right now....
-Kyle
Old 03-22-2007, 11:59 PM   #5
Bryants95240sx
Bryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the roughBryants95240sx is a jewel in the rough
Yea a aftermarket gauge is your best bet, the stock gauge acts like its on crack at times.
Bryants95240sx is offline   Reply With Quote
Old 03-23-2007, 12:16 AM   #6
LB.Motoring
LB.Motoring's Avatar
If you invested enough money to buy an SR,
I would atleast spend some money on watching it and protecting it.........
Robby Leuer
Old 03-23-2007, 12:17 AM   #7
dirtdiggler666
dirtdiggler666's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
ok mine did the same thing but i have a ka im sure its close to the same thing,look where your top rad hose goes it should be close to that, it should be one wire mine came lose and it was jumping all over the place then i fixed it and it was fine.its hard to say what it looks like but look neer their for loose wires
dirtdiggler666 is offline   Reply With Quote
Old 03-23-2007, 03:37 AM   #8
Munch
Munch's Avatar
Munch is an unknown quantity at this point
My car did the exact same thing for a long time.
You're problem is your gauge temperature sending unit. I'm not sure if its the same on an SR, but on the KA, the sender is on the intake right next to the coolant temperature sensor.
The plug on mine was some kinda spade connector and it was pretty much broken, but not completely off.
If your problem is the same as mine was, the needle drops when u give it gas because the engine torques and tweaks the sender just enough that it loses connectivity.
Munch is offline   Reply With Quote
Old 03-23-2007, 05:23 PM   #9
Atljunglist
Atljunglist's Avatar
Atljunglist is an unknown quantity at this point
My stock gauge acted up too. The gauge on the cluster went bad so i just went aftermarket. Besides the stock gauge only has 3 settings.....cold, warm, and engine fucked. Autometer gauges are fairly cheap if your on a budget.
SR Powered S14
T-28, FMIC,
Atljunglist is offline   Reply With Quote
Old 03-24-2007, 05:52 PM   #10
zerooath
98 Kouki Slicktop. Tip Dealer!
zerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to all
Send a message via AIM to zerooath
how much does a a pillar pod gauge and gauges run usually?
zerooath is offline   Reply With Quote
Old 03-24-2007, 05:57 PM   #11
staygold24
staygold24's Avatar
staygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enough
mine did that all the time and i fixed it. It was just a loose temp sensor. I just fixed it recently mines on an sr and was just the loose metal piece. Just check it out tighten it down maybe clean out the sensor by pouring backing soda and water to clean it out some and brush off the metal piece with some cotton wool or something abrasive to clean it of any residue or oxidation on the metal piece.
staygold24 is offline   Reply With Quote
