Old 08-19-2002, 01:43 PM   #1
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
well the freight company just dropped my LSD off. Its a JDM Lsd off a silvia s14. hope it fits <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> . anyway, after inspecting it and taking a hard look at it. i was wondering, where do i put the oil in? i am looking for it but just cant seem to see it. i must be blind.
also, is there any special thinks i should look at to inspect before i install?
i will have pics posted shortly.
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline   Reply With Quote
Old 08-19-2002, 02:01 PM   #2
sil80
sil80 is an unknown quantity at this point
LSD install
VLSD on the left has a incoming connector to the right of the yellow one.. is that not it?
Five degrees of separation - from you and your license
91 240sx SE
sil80 is offline   Reply With Quote
Old 08-19-2002, 02:04 PM   #3
boosteds14
boosteds14's Avatar
yep the one on the left is the one. i must be as blind as a bat because i didnot see that pipe until i looked again.
thanks
240SXONE
Old 08-19-2002, 02:06 PM   #4
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
isn't that a breather? &nbsp;i think you should just fill it through the drain plug. &nbsp;just tip it on end, and pour the recommended amount of fluid in.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-19-2002, 02:21 PM   #5
boosteds14
boosteds14's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">isn't that a breather? &nbsp;i think you should just fill it through the drain plug. &nbsp;just tip it on end, and pour the recommended amount of fluid in.</td></tr></table><span id='postcolor'>
ya that is what i think, but i could be wrong. after looking at it for the third time i think that is a breather
now what fluid do i use for this LSD. it is not a VLSD.(from what i was told when i bought this.)
240SXONE
Old 08-19-2002, 02:28 PM   #6
sykikchimp
WOW addicted
sykikchimp's Avatar
If it's a Stock Silvia LSD then it has to be a VLSD. &nbsp;On the 240 Diff isn't the fill plug on the left side? &nbsp;Maybe it's in the same place as the drain plug?
Also are you gonna have to swap Diff covers? &nbsp;b/c if the one you bought looks like the one on the left it won't bolt up will it?
Old 08-19-2002, 02:31 PM   #7
boosteds14
boosteds14's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Also are you gonna have to swap Diff covers? &nbsp;b/c if the one you bought looks like the one on the left it won't bolt up will it?</td></tr></table><span id='postcolor'>
its an s14 this is going into. bolts right up.
240SXONE
Old 08-19-2002, 02:48 PM   #8
boosteds14
boosteds14's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">If it's a Stock Silvia LSD then it has to be a VLSD. &nbsp;On the 240 Diff isn't the fill plug on the left side? &nbsp;Maybe it's in the same place as the drain plug?
ok i went to look at it for the fourth time. the drain plug and the fill plug are in the same position as the stock one i got on my car now.
but is it a vlsd.?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> how do i check this. &nbsp;do i need to pull the cover off? and again. WHAT OIL DO I USE??
240SXONE
Old 08-19-2002, 06:02 PM   #9
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
if it is off of an S14, it is a VLSD
iirc only the s15 used anything else (helical i believe)
you could just talk to the friendly local nissan dealer as the diff oil should be the same
Camppain? &nbsp;any clues?
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
Old 08-19-2002, 07:08 PM   #10
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
http://www.zilvia.net/installs/installs.asp
There is a LSD Swap writeup in there.
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
