Old 04-04-2007, 11:55 PM   #1
pretending2bepro
pretending2bepro's Avatar
pretending2bepro is making his/her stupidity well-knownpretending2bepro is making his/her stupidity well-knownpretending2bepro is making his/her stupidity well-knownpretending2bepro is making his/her stupidity well-knownpretending2bepro is making his/her stupidity well-known
subs, diffs and alot of fun
ok, this may sound relatively newb but i would rather accept the bashing than rip apart my '95 240se and be left with nothing...
whats going on is im replacing my subframe and i have a few questions, i may have come across an entire rear end (sub frame, axles, arms, vlsd, etc.)...
well first off i have the 6 bolt axles from the open diff and i would like to know if if i could still use the axles somehow with the vlsd, my understanding is that the viscous is a 5 bolt
also, i have the 5 lug and i just need to know if its a simple matter of bolting the 5 lug hub in place of the four...
finally is there any gearing difference between the auto trans diff and the manual trans diff?
yeah bash me all you want but i appreciate all the help i could get... thnx!
pretending2bepro is offline   Reply With Quote
Old 04-05-2007, 12:07 AM   #2
projectRDM
projectRDM's Avatar
I'd bash you, but I can't read that garbled up one huge ass sentence without a bit of proper punctuation to know what you're asking.
Old 04-05-2007, 12:15 AM   #3
pretending2bepro
hows that? i didnt think it was that bad, but w/e it takes to get a little help
Old 04-05-2007, 12:31 AM   #4
eastcoastS14
eastcoastS14's Avatar
^^ first off can i ask why you are replacing your entire rear end? also most of your questions i believe have been covered before...seriously just search around and i think youll find most of you answers...theyre good questions but ones that a lot of ppl have had before you.... ppl will flame but w.e search then post and youll be straight
eastcoastS14 is offline   Reply With Quote
Old 04-05-2007, 01:31 AM   #5
sleepy_s13
sleepy_s13's Avatar
sleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to behold
theres no need to change your subframe. unless its bent? and you cant use the 6bolt axels. thats why they gave you the five bolt. and as for the hubs Ive never converted them
sleepy_s13 is offline   Reply With Quote
Old 04-05-2007, 02:29 AM   #6
!Zar!
!Zar!'s Avatar
Hmm. I'll try my hand at this one...
You don't need to swap your subframe for any reason unless you destroyed it in some mad tyte drifto action.
Not all vlsd's are 5bolt.
You have five lug what from what? You're too vague.
There is no diff, "No pun intended" between the at/mt rear ends. Only reason why it wouldn't work is if the pumpkin came out of a car with/without abs.
Damn, I'm the shit.
Old 04-05-2007, 09:15 AM   #7
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
a s14 vlsd is 6 bolt. The 5 bolt you speak of is most likely out of an infinity J30, which will also work(provided you have axles)
EDIT- If the subframe you have HAS a 5 bolt in it, what is it out of?
gotta240 is offline   Reply With Quote
Old 04-05-2007, 09:25 AM   #8
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Wow, this could be answered by the old age SEARCH.
Search terms for you:
S14 Subframe swap
VLSD 5 bolt
S14 5 lug conversion
Old 04-05-2007, 02:10 PM   #9
bauchrb
bauchrb is an unknown quantity at this point
I got a 6-bolt out of a J30, it bolted directly into my s13...
bauchrb is offline   Reply With Quote
