Old 08-27-2002, 02:44 PM   #1
ue drift
ue drift is an unknown quantity at this point
this guy i met has a 91 na 300sx rear end.he says it has bad PINION BEARINGS .what are those?does it have anything to do with the vlsd?and what else would i need for this swap?thanks alot for your help!
ue drift is offline   Reply With Quote
Old 08-29-2002, 08:54 PM   #2
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
You could replace the bearing yourself, but you'd have to make sure the pinion's lash lines up (the pinion and the gear mate up correctly).  Best thing to do would be have a gear shop do it for you.
If I'm not mistaken, the output shafts on the Z LSD are a five star bolt pattern (with a bolt hole on each star point), and the S13 has 3 stars with 2 bolt holes on each of the 3 star points.  So, you'd need the output shafts and the bearing replaced.
-m
400x200
mbmbmb23 is offline   Reply With Quote
