hey if you want to add auto start your in good luck. since you work for the city you guys sell the dei alarms. dei makes clifford,viper and dei. buy any G4 series alarms i belive circuit sells the ace500 and higher, and also the auto start. G4 has a buit in safty for man. trans. you can not start the car in gear it will send a warning tone to tell you if your in gear. I work for Goodguys in cali. if you cant buy the g4 ace500 in wash. you can add a auto start by accel goodguys carries this aswell as all g4 prod. it works fine in my 95 easy install about 1 hr to add on. if you cant do either you can add a magnetic switch to yor neutrel position as a closed circuit. any alarm with avail options will see a closed ciruit and only activate auto start when in the nuetral pos. hope this will help
Im out-e like your belly button
