Old 04-14-2007, 04:43 PM   #1
Gnnr
Gnnr's Avatar
Post Overheating woes
My car is a mystery.
First off, its 95 stock auto 240sx.
Now, I've been running without a thermostat for almost a year now. When I had a thermostat in I would overheat. Running without one though I would be fine. But doing so causes the engine to run in open loop, which gives really really shitty gas mileage and the car feels like ass. Since I've been running fine for so long without a thermostat, not overheating at all, and gas prices are so high and I'm trying to do I can to get the best possible gas mileage out of my car (its my daily). I figured I put one in so I can improve my gas mileage.
So I bought a new thermostat from the dealer, put it in, and again I rapidly overheat. Without it I'm fine though, so that makes no sense. If it where a blown/warped head it would overheat with or without it, wouldn't it? Same thing if it where the water pump I wold think. No signs of a blown headgasket (oil in coolant or white smoke) has shown. The radiator is new and so is the cap. No leaks that I'm aware of. Using the electric Taurus fan on high and using 50/50 coolant. Whats left? Maybe the stock thermostat opens too late. Should I try a Nismo thermostat? I don't know. I'm lost.
Gnnr is offline   Reply With Quote
Old 04-14-2007, 05:01 PM   #2
umsports
umsports's Avatar
umsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura about
Take out the actual spring and thermostat part of the thermostat and run it like that.
2010 R35 GTR 600whp @21 PSI (E85)
1998 RB26DETT 240SX 810whp@28lbs
umsports is offline   Reply With Quote
Old 04-14-2007, 05:47 PM   #3
hipro
hipro is an unknown quantity at this point
For some reason, most after market and Nissan stock thermostats are set to open at around 170 degrees F (72.5 degrees C). For my '95, I had the same problems until I bought one of the Nismo lower temp thermos. It is designed to open at 144 F (62 C).... worked for me. Do a web search for Nismo lower temperature thermostat or go to http://www.nismoparts.com/catalog/?section=619 (about $54). I believe mine cost about $50 compared to the $10 everyday variety. Hope this helps.
hipro is offline   Reply With Quote
Old 04-14-2007, 06:48 PM   #4
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
make sure your cooling system is bled completely. im just throwing out ideas. your oem thermostat should be good enough though. did u make sure when u installed the thermostat that the jiggle valve was at the top? i dont know if that would make a big difference.
ladiesman8527 is offline   Reply With Quote
Old 04-14-2007, 08:01 PM   #5
Gnnr
Gnnr's Avatar
Forgot to mention that thats the way I had it. With the spring cut out when I was running without the thermostat.
I guess I'll have to give that shot. Thats kinda pricey for a thermostat, but I'm out of options at this point.
Yes, I installed it with the jiggle valve at the top. As far as bleeding, even if it was bled incorrectly, why does it only do it with a thermostat? Wouldn't it also overheat without one if it had air in the system? This was the second thermostat I bought new from the dealer just to make sure I didn't get a defective one the last time I tried to get this whole thing working.
Thanks for the replies. Anymore thoughts?
Old 04-15-2007, 07:11 AM   #6
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
Might be a little easier to bleed without the thermostat in place.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 04-15-2007, 08:25 AM   #7
g6civcx
g6civcx's Avatar
Test the thermostat by suspending it in a pot of boiling water (hang it on a string from a chopstick to keep it from getting too hot at the bottom of the pot) and a temperature gauge. It should start opening around 150-160, and should be fully open at 180.
It may be that you bought a couple of bad ones. Start with that and see how it goes.
Your problem is really weird though. How do you know you're overheating? Don't trust the stock temp gauge. Get a real gauge.
Old 04-15-2007, 10:31 AM   #8
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
The car *should* work fine even with a stock temp thermo. My guess is that a) its probably not an OE thermo - the cheap auto parts place ones can be very hit or miss and you can get one that wo't work correctly
b) You are not bleeding the system properly with the thermo installed, and without the thermostat in the car, its bleeding ok and thus the car isn't overheat.
I would do what g6civcx suggested and test the thermo you have, if it checks out ok, reinstall it and try bleeding the system again. If you ask two different people you will probably get two different methods to bleed the coolant system, but I like to park the car on a hill, pull out the bleeder screw while filling the rad with a hose, wrap a towel around the hose and the rad opening and semi-pressurize the system. Water and air will then spray out of the bleed hole. I learned this trick from a friend that, at the time, worked for C&R radiators. We used this method when we did our radiator testing a few years ago. Once you have a nice stream of water I usually repace the bleed screw and start the car. Make sure the heater is set to full hot and let the car warm up. As the thermo opens you may need to add a bit of water/coolant. Cap it and go drive.
And like mentioned GET A REAL TEMP GAUGE as the stock one is absolutely useless.
Big Bronze Rim is offline   Reply With Quote
Old 04-15-2007, 10:42 AM   #9
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Do you have to refill coolant often? Blowing coolant into the overflow tank? My guess would be a blown headgasket, or something leaking at temp. Otherwise how is the radiator cap?
I recently had a problem where I blew my headgasket. It was sealed when things weren't expanding too much, but heat and pressure would cause cylinder compression to leak into the coolant system, blowing coolant out and creating air pockets. Ran fine with the thermo out, and overheated almost instantly with the thermo in. Compression tests didn't even pick up on it since it was sealed when relatively cool.
AceInHole is offline   Reply With Quote
Old 04-15-2007, 05:24 PM   #10
Gnnr
Gnnr's Avatar
Maybe, we'll see when I try a Nismo one.
I'm using a Greddy MSS with temp signal wire taped into the ECU. Without the thermostat it pretty much stays at 145F.
They where OEM. Direct from my local Nissan dealer.
When I try the Nismo thermostat, I'll try your method of bleeding. Thanks.
I don't remember seeing low coolant in the reserve. I'll monitor the level closely to make sure. It will blow coolant into the reserve after it overheats, but that only happens with the thermostat in. Radiator cap is new, OEM from my local Nissan dealer as well.
With my luck, I might have weird stuff like that happening. Besides the overheating, where there any other signs. Because I can't see anyother signs off a blown headgasket.
Thanks for the help so far guys.
Old 04-16-2007, 08:10 AM   #11
AceInHole
Autox Technician
AceInHole's Avatar
Couple things to look for:
1. overflow tank filling up and not draining (or overflowing)
2. black particles in coolant
Old 04-16-2007, 10:02 AM   #12
Canaduh
Canaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of light
Just thought i'd throw this out there, but friends car does the exact same thing. He's kinda confused about it as well. We did do the boiling water trick, and sure enough the thermostat opened, He didn't put it in backwards either. Strange too, as his is a 95 as well. Lol. I dunno, siorry i couldn't be much of a help, but your'e not the only one with this problem.
Canaduh is offline   Reply With Quote
Old 04-20-2007, 08:50 PM   #13
thejester03
thejester03 is an unknown quantity at this point
Send a message via AIM to thejester03
compression check
Signature Exceeds Forum Limits
thejester03 is offline   Reply With Quote
